I guess great minds think similar.
I saw an article in Countryside magazine last spring where a guy in the midwest was stacking split wood in 4 piles per pallet and then using shrink wrap to season it.
I adapted it for our environment (pretty dry most of the time) and almost completely pine/fir (a wee bit of aspen). Anyhow, I took some unused pallets and some 51 cent 2x4's from Home Depot and nailed 'hoops' about 8~10 inches from the front edge, then repeated every ~16". So you end up with either 2 or 3 hoops per pallet. Nailed the hoops on the inside of the 2 x 4 runners, then nailed the tops over the uprights. It is working well, where I place the wood as I cut or split it on the pallet, then move it into the garage as needed (my tractor will not fit inside -- but SWMBO has a minsteer that will). One pallet is about 1/4-1/3 cord.
I bought one of those Northern Tools welded 2 x 4 wood rick frame kits (steel you insert the 2 x 4's into), then made a 3rd piece. I inserted it into the middle so I can load it all with wood, then use one side. Then I load it with any wood that was outside. It drys out by the time I have used up the other side. That way I don't worry about covering it.
But with the 'next step' a few of you have gone to (don't move it again off of the pallet until it is time to take into the house), I will have to rethink my process. Maybe rearrange the garage space a bit and have room for two pallets (one dry, one fresh).
By the way, the long 3 hoop pallet isn't working so well, too much effort to load the middle hoop and to unload it. Next year I will be standardizing, and considering the slide in sides modification. No top to the 'hoop' then.
I don't know the issue here, but my wife reread the manual to our Vermont Castings stove recently and it calls for a mix of dry and wet wood (it doesn't define that as green, or simply not completely seasoned). We are experimenting to see the effects. All I can figure is that it could be for three reasons: creates a better mix of combustible gases; slows the burn down a bit (maybe less peak temps); helps control formation of stuff on the flue walls (words are escaping me at this time) to reduce fires in the pipe.
