Chevron Synthetic All Weather THF
   / Chevron Synthetic All Weather THF #11
DieselPower... thanks for the lead on the TRC fluids... I've sent them an email asking for more information. Will report back when I get it.
Now, for my dumbs to hang out.. what's a UOA, where do I get it, what is the cost? I like the idea of extended use, not throwing money away.
As regards the Chevron.... dead end
When I call the local distributor, he didn’t have a clue. So, he called the Waco warehouse. The story is that they do not now and never have had any in stock… and, if they did, it would be 55gal drums, which is much more than I need (one complete change is 12 gallons, so 15 gal total is needed). So, me getting this oil in Texas seems to be a dead end.
   / Chevron Synthetic All Weather THF #12
Any idea as to how much this product is? It looks appealing enough to prompt some serious consideration.
   / Chevron Synthetic All Weather THF #13
John- I enjoyed speaking with you on the phone a little while ago. I shot you a reply to your email.
TRC's UTF and UTF Red is:
$142.80 for a case of 24 - 1 quart bottles
$99.60 for a 6 gallon pail ($16.60 per gallon)
$570.50 for a 35 gallon 1/2 drum ($16.30 per gallon)
$858.00 for a 55 gallon full drum ($15.60 per gallon)
All TRC lubricating oils include free UOA's (used oil analysis).
   / Chevron Synthetic All Weather THF #14
DieselPower, thanks for the phone discussion and reply..lots of good information! I learned an immense amount, including the following:
Summary for everybody: I'm going to switch to:
UTF RED for my hydraulic oil, it meets the Kubota SUDT specifications and is colored so you can see it on the dip stick and find leaks.
Moly XL Pro-Spec III synthetic blend multi viscosity engine oil 10W/30
for my engine oil. It, too, is uniquely colored for visibility of leaks and on the dip stick.
Moly 880 Crown and Chasis Grease
I'll consider switching to a grease gun loader pump ($50 or less) since this comes best priced in 45lb pails (6 gal)
Reasons
UTF RED is about $16.60/gal or less, SUDT = $17 best I could find on net. It also has components that help seals to retain/regain their function, thus avoiding/reducing/fixing leaks. Maximum pour point (F) = -40 (SUDT = -46F, but either way, it's too cold in Texas to be on a tractor:eek:)
Moly XL Pro-Spec III engine oil = $101/6 gal = 16.95/gal = 4.24/quart = price comprable to the Mobile 1 synthetic diesel oil I have been using. I like the idea of adding Moly compounds to all metal surfaces for added protection.
Moly 880 Crown and Chasis Grease also provideds moly components for the extreme pressures of FEL work and I like that. My only concern is that quantities of 45lb ($222) will take a long time to use up, probably my lifetime. On the plus side, it's shelf life seems to be superb, with no oil leak out even after years of sitting.
The main selling point for me is that free used oil analysis (UOA) is included in the price for any of the TRC lubricants. You take a sample at the regular drain interval, and then at intervals afterwards until the results indicate it is time to drain the product. This means that I can achieve the extended drain intervals that I want and can expect from the superior fluids.
This matches my scottish ancestery, busy schedule (and distaste for a messy project). In the past, I've purchased SUDT and Mobile 1 or Rotella T Synthetic oils, run them longer than the typical drain interval, but been forced to drain them without actually knowing if they had reached the end of their functional life. In fact, when I drained the products, they actually looked just fine. With the TRC products, it looks to me like you pay the same price or less, but drain only when needed, thus actually being able to benefit from the quality oils purchased and care/maintence I provide to my tractor.
Oh, yes, the final kicker is that when the total order is $300 or more, shipping to my front door is free as well. Under $300 is $20 handling. This isn't hard to achieve, 12 gal UTF RED + 6 gal of Moly XL Pro-Spec III = $300.90:D That's exactly the quantity I need for 1 complete drain/fil, no surplusl:D
Oh, and another thing, I CAN GET WHAT I NEED WHEN I NEED IT. The Chevron synthetic THF product can't be had. The SUDT requires me to make a 80 mi round trip to get it. :p
So, what's not to like... well, I kinda wish I'd discovered all this before my 600 hour service that I just did..... but, there will be another one in the future and I'll already have the fluids on the shelf ready to go!
I know that there are many good lubricants out there that do just fine. However, when I looked at the TRC products, at every turn there seemed to be something that was just a tad better than it had to be and = or better than my alternatives. I've only listed a few of the items that caught my attention above, there are more but I can't remember them all. So, I'm gonna give them a try and expect to have extended drain intervals, early warning via UOA should engine or hydraulic component failure be beginning, and product availabllity when I need more.
My tractor is a big investment and I want to give it every chance to run superbly beyond the end of my lifetime. For those who may wonder, I have no relationship to DieselPower or TRC lubricants other than via TBN.
   / Chevron Synthetic All Weather THF #15
Man oh Man, thats going to encroach upon $250 or so including freight for my Bota'. :eek:
texasjohn said:
Reasons
   / Chevron Synthetic All Weather THF #16
If you get $300 of product, handling is included.... shipping to your door....
   / Chevron Synthetic All Weather THF #17
Diesel Power,
I have been using Chevron All-Weather Syn THF on my 5030HSTC since it's 50 hour service. I have no problems obtaining it in 5 gallon pails, and I am pleased with it.
I did notice improved start-up performance in cold conditions (-25F); easier starting (also using Mobil 1 Turbo Diesel Truck for the engine) less than a 5 minute warm-up and I am ready to work. We also get +100's here in the summer so I need fluids that handle extremes.
How does the UTF RED compare to Chevron All-Weather Syn THF?
How does the Moly XL Pro-Spec III synthetic blend multi viscosity engine oil compare to the Mobil 1 Turbo Diesel Truck?
Not trolling; serious questions.
   / Chevron Synthetic All Weather THF #18
The main difference is that the TRC lubricants have very robust additive packages. In some cases they have up to 5 times more additive when compared to off the shelf oils. Anti-oxidation, anti-wear, anti-foam, etc... additives are consumed in the operation of equipment. The increased levels of additive tend to increase lubricant and equipment life.
I like their company moto. "Our products have never been built to a price - rather they have been built to a need."
   / Chevron Synthetic All Weather THF #19
DP,
Are the UTF RED and Moly XL Pro-Spec III full synthetics?
   / Chevron Synthetic All Weather THF #20
No. In 85 years of formulation and blending they have found that they can suspend a much higher additive package in conventional and synthetic blend oils than they can in full synthetic's (not that synthetics have been around for 85 years). Synthetic's do not have as high a solvency to additives as conventional base stocks do. Where conventional base stocks have great solvency for additives. Actually even full synthetic's are not truely a "full" synthetic. Some portion of the oil is conventional. The small portion of conventional used in full synthetic's is used for one reason, additive solvency and is often refered to as the carrier oil since it is what carries or suspends the additive package in suspension. There are many different way's to formulate a lubricant and the final blend and how it performs is the true test for any lubricant.
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A55218)
2022 JCB 3TS-8T...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
TEREX RT665 MOBILE CABLE CRANE (A51406)
TEREX RT665 MOBILE...
Dump Box Truck Body (A52377)
Dump Box Truck...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
1996 International Water Truck with a Caterpillar Engine (A55218)
1996 International...
