Chicken Tractor
   / Chicken Tractor #1
cmhyland
Platinum Member
Woodstock Valley, CT
2000 Kubota B2910
Anyone build a Chicken Tractor? For those not into the chicken lingo.... It's a moveable chicken coop with a small moveable run attached to it... It allows you to move small quantities of chickens around the property.
I'd love to see some pics of what people built. Below I have added a sample i found on Google images.
Regards,
Chris
   / Chicken Tractor #2
A coworker has one. I think he has some pictures of it but usually when he openly talks about it at work he gets a ration of **** from the rest of us.
   / Chicken Tractor #3
I don't have the link here but there is a chicken forum where they have tons of pics is these as well as plans. When I get home ill see if I can find it.
   / Chicken Tractor #6
I've got a picture of one I want to build .....but it's still in my head. Build a rectangle out of 2x6s 8' x 16' placed on edge. Drill holes every 2' to put pvc pipe into. Bend the pvc and glue it to a center pipe that runs the length of 16'. put wire over all that to create the run. Build a box on one end for the coop. ....basic idea -- I have details I'll finish when I draw it on paper before I actually lay a hammer to it. This was a project I had hoped to do this past winter - but other things got in the way. Guess I'll hope for it next winter. Too busy during the summer.
   / Chicken Tractor #7
The kid and I wend to a chicken seminar Friday night (most folks go to the movies). I am tossing around the idea of chicken tractor VS fixed pen and coop. On the one hand a chicken tractor looks good for a couple, three birds.... until it snows! Then what? And what about the bottom of the thing VS predators? And what if you have to get in it? On the other hand, a fixed coop and run can be made large enough for more than a couple, three birds. I'm thinking I want 5-6. And it can be made more predator proof. But, its more expensive to construct.
   / Chicken Tractor #8
I built this one to be a Chicken Tractor, movable by my Tractor... 6 birds in this coop and can move it any time I want. I did wire it up with electric fence to keep the raccoons out. I have repurposed two other more permanent structures as well but I am glad I have both.
   / Chicken Tractor
Thanks for the pics Triguy1,
I saw these online as well.... They look pretty good.
Regards,
Chris
   / Chicken Tractor #10
I documented mine on Backyard Chickens many years ago when I built it. It is big enough for 5-6 birds, but it's heavy. During the winter it is frozen in place. I acutally pulled it into the barn before a few snow storms. In the end I'd just free range them. I build a separate coup and run which can hold more birds, has electricity so I can have a heat lamp for new birds. I got tired of having birds in two locations when I'd get new chicks. There also was always a problem integrating the young and old birds. I never have any issues.
The chicks are separated in the main coup from the older birds. As they get bigger I open up a small door which they can go into the main coup, but the big birds can't get to them. Much easier.
I did use the chicken tractor last year for meat birds. 25 fit in there without any fighting.
2020 FREIGHTLINER CASCADIA 125 SLEEPER (A54607)
2020 FREIGHTLINER...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
