chimney problems
   / chimney problems
The chimney is right at the peak of the roof and is about 4.5' above the roof line
   / chimney problems #22
I was talking about the stove pipe ,from the stove to the chimney(between the stove and chimney)
   / chimney problems #23
1. make sure that all the stove pipe joints are tight we want no room air going in the chimney.
2. make sure the pipe is in the chimney flush with the tile and that it is cemented in, we want no room air going in to the chimney.
3. look at your clean out door if their are any air leaks, check it with a match run it around any gaps or cracks if it sucks it in duct tape it shut.
4. if you can build hotter samller fires avoid loading it up and closing down the air.
5. If you put your stove therm on the stove pipe 1' away from the flue collar you should have 350 to 500 deg. at this temp. your chimney should stay hot enough to prevent the build up.
6. creasote will condense on the surface if is below 250 deg. The goal is to keep the chimney hot hotter is better
Is most of your build up at the top of your chimney???
Rich
   / chimney problems #24
Wow, Sitting here reading this and it is really warm here in the basement. My burner has an adjustable auto damper that I have presently set so the stack runs about 350.......
   / chimney problems
richh
Thanks for all the info I will check into that .
Most of the plugging is about 4 feet above the thimble and down
CATERPILLAR 303.5 CR EXCAVATOR (A52705)
CATERPILLAR 303.5...
American G-Model Pump Jack (A55218)
American G-Model...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
ALUMINUM WHEELS AND TIRES (A53843)
ALUMINUM WHEELS...
