Chipper chipper won't chip
   / chipper won't chip #1
wsurph
BCS 722
Hi , I've got a 2013 BCS 722 tractor that I bought new and use almost exclusively for garden tilling. I say almost because when I bought it there was a deal to get a second attachment at a discount so I got the BCS Bio100 and I used it when new for about a dozen hours until yesterday when I wanted to get rid of some branches from a recently cut tree. After connecting to the tractor it worked fine for about 10 minutes then stopped chipping. I cleared where I thought it might be jammed without success, then disconnected the PTO to assure there was still power (there was), reconnected, still no go, checked the belts and pulleys on the chipper and they all turn with the PTO engaged, but the drum and knives don't move. I'd appreciate any thoughts you might have as to what the problem is.
   / chipper won't chip #3
Exactly. Somewhere there is a sheared shear pin. Check your owners manual for the chipper.
   / chipper won't chip #4
Feedback. Did you find the problem??
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
