Chipper
   / Chipper
Shredder
Thanks for the further responses, and again I apologise for the thread title, it is confusing some posters. Elsewhere I have been the two descriptions appear to be interchangeable. Can it be changed to "Shredder"? I managed to change it on this post but cannot edit tthe earlier ones.
CalG, After reading a fair bit more on the net this evening, I am convinced that hammers are necessary. I do like the look of the MacKissic machines. Would you recommend a screen size of 25x50mm as you have? Power is not a problem using my tractor's pto and I do not need a fine chop. The idea is to cultivate the shredded material into the ground.
I began thinking about it earlier in the week when I realised that the depression I am filling with the current prunings will be easily filled long before I am finished. I would need to spend many days, probably several weeks, with the Bosch and that is a non-starter. The depression will eventually become reclaimed land. I did a similar job on 2000sq metres and a metre and a half deep (an old stone quarry I think) in 2003-05 and now have olives planted on that land. The present area is just a couple of hundred sq. m. This article began my thoughts Whole Orchard Soil Re-incorporation: an Alternative Orchard Removal Strategy - The Almond Doctor not that I need an Iron Wolf, the machine that incorporates whole trees into the soil.
Mysfyt, I do not own a camera, but might be able to get somebody else to take pics.
   / Chipper #12
OldMcD
I was not accurate in my recollection of the screen size.
The screen on my machine is about 32X150mm oval openings. A read of the MacKissick web sight literature will confirm that sizing and optional screen panel offerings. Green fruit tree and hardwood trimmings come out cleanly as shredded material with an occasional "Missile", that must have aligned perfectly with hammer and opening to be ejected with such force ;-). (Not very many, but they hurt if you are on the receiving end of one)
I would not suggest smaller openings for woody material (or any material really.) A second pass through the hammer mill reduces nearly any vegetative material to a fine texture.
If I were "designing from scratch", I would angle the feed hopper to allow more comfortable introduction of the material to be shredded. I am fully 183cm tall, and still tire of reaching up to feed branches into the hopper.
A second design feature would be a Quick clearing" screen feature. Some sort of a screen mounting scheme that allowed the screen to pivot clear of the spinning hammers and allow dumping of any build-up or clog. The MacKissick unit has a screen retained by long pins through the drum body, and should be easily dumped, but the pins are obstructed, with tools required for removal.
A third aspect is with the discharge. Shredded material builds up rapidly. By far the best practice is to lift the unit with the tractor 3ph and drive forward, leaving the pile behind.
If you can position at the edge of a bank or depression, so much the better. Just be sure to leave ample room beneath the unit!
ETA Having now read the referenced article on reincorporation of organic materials. I commend you for your efforts!
I tired of burning. and now enjoy a continuous supply of composted organic material to add tilth and vitality to the soil. The future looks good!
   / Chipper
CalG, Many thanks, just the sort of info I was looking for. With that screen size, output should be high. You confirm my thoughts on discharge and moving the tractor. After completing the fill of the current depression I am dumping prunings into (almost full after this morning's efforts) I will be on flat ground and intend to make long windrows, shredding and then moving along the row as necessary.
For this year, the leaves are likely to fall off before I begin shredding. No harm in that since they will be where I want them. The shreddings would then be directly cultivated into the soil the same as is done with the Iron Wolf, but on a somewhat smaller scale. It will obviously improve the soil immensely - given time and some TLC based on complete soil and leaf analyses, which I do on a regular basis.
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
Woods PF4448S 48in Forks and Frame Skid Steer Attachment (A52377)
Woods PF4448S 48in...
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
