TimberXX
Platinum Member
- Joined
- Feb 4, 2005
- Messages
- 830
- Location
- Bergen County, NJ
- Tractor
- BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
and when you pull the tarp off, always be aware of little nasty stinging dudes who might be constructing their single unit, multi family home under the tarp!
As others have noted........it is sitting up on the metal skid that it was shipped (IIRC), as well as some concrete blocks. The top is first covered with some old feed bags to slow the wear (sharp edges) on the tarp............and "Yep" the wasps and frogs like to find a home inside.
Cheers,
Mike
any recommendations to stop pests? what type of grease would you use. think fluid film would work?
that's odd that could happen!. I put a piece of plywood on the top of my cast iron tablesaw in my shed to prevent rust, that works perfect!.You will find that your metal skids will firm surface rust where they make contact with any surface including the wood. You will not eliminate that unfortunately. You can reduce it by removing some planks. A good treatment of oil and keeping on top of rust with either a wire brush or a brush and rust convertor and paint are a must even more so in a humid climate.
If you removed the chute, would you be able to rearrange the inside of your canvas storage to have it inside when it is not in heavy usage? Then use outside storage and tarps during regular usage periods?
