Choices.....
   / Choices.....
Dmace said:
Comparing the Mahindra 2415 to the Kioti CK20, it looks like the Mahindra does not have an adjustable suspension seat since it can fold forward. The Kioti with the KL130 loader can lift 1074 lbs to full height (88") at the pivot points and the Mahindra with the ML105 lifts only 1050 lbs to a max height of 83" at the pivot points. This is comparing a 21hp tractor to a 24!
Comparing the backhoes (Kioti KB2365 to the Mahindra 1710B) the digging depth of the Kioti is 76.4" compared to 76" for the other. Bucket digging force for the Kioti is 2875lbs where the Mahindra is 2520lbs. The Kioti reach is 105.5" compared to 105" on the other. It seems like they are very close but this comparing the Mahindra to a smaller tractor.
For it's size, the CK20 is an incredibly powerful machine. There is less than 100lbs difference between the two machines so if the Kioti seems too heavy for mowing, the Mahindra will be too!
Either machine will amaze you...
Thanks for the reply......
The CK25 is too heavy to mow not this bugger.
Both are very close in size if you have seen them both. No real major differences there. 2615 is much bigger framed. One thing I really like about the Mahindra driving it was ease of mounting and dismounting thats huge for me. (bad back) Also the hindra seems easier to manuever .....
Yeah, I signed in twice, I thought because it took so long to get registered my first attempt failed. Sorry.....bout that. Sometimes spam filters kick out useful stuff. :p call me sybil59....
I've been lurking awhile now and going to dealers for two years asking questions. (yep slow learner) I just wasn't ready before and now am after my cellar took some H20 this winter. I decided to rip up my yard and re-drain the whole kit and kabootle...
As for mowing its last on my list of things it must do well. I already own a nice small lawn tractor that I'm not done popping wheelies with yet. er' I meant mow.....
Back to my choices and why.
The mahindra 2415 has a shade faster bucket response. I also believe these two are the closest in all categories except engine hp/pto nevermind price its very close again. I love the idea of a throttled down engine 2500rpms I know piston speed is a major engine wear issue. TYM same engine 2700rpms, the 2615 same engine 2600rpms. So this engine is being under utilized or the others over or slightly over. The reviews are scarce so not alot of feedback from owners. Lastly, this dealer is closest and super nice guy and never tried hard selling me which is huge! IIRC, the seat does in fact slide forward , but no suspension built in. It fit fine anyway. :) Digging force according to the site is 2900lbs?
CK20 has by far the most room for me on the hoe. The CK20 also comes with a few extra goodies iirc. 3pt hitch .. I actually thought the kioti had less digging depth. I need to re-read that , but it seems the site is down. Either way it's very minor.... FEL controls on the CK are in a better spot, although , it limits mounting the machine from that side. I fully agree the seats are better on the Kioti the drivers seat has a suspension built in...these are little things that if you are working it alot matter imo.
Kioti CK20 Review, Price, Information Any thoughts on this review?
My wife thinks RED goes with the house better. :D
   / Choices.....
coasterez said:
If you haven't driven the T273, the manueverability of that little machine will amaze you. The only thing about the Mahindra is the location of the loader joystick. I find the ones mounted up high on the loader frame to be very fatigueing, much like holding your arm over your head for a long time. But, I don't have the longest of arms either.
I agree !! But, I have long arms and the mount is adjustable. The TYM is out of the picture the out of state dealers price was ridiculous the in state price of the machine is between 1-2k more.
I just can't justify the price difference. I need to call another dealer on the TYM , but its furthest away. Thats what makes it tough ...
TYM also has the higher HP , but its the same engine as the mahindra.
heads or tails......;)
   / Choices..... #13
At first, you were comparing the Mahindra 2415 to the CK20, that is the numbers I used. The 2900lb digging force is for the 3710 backhoe on the 2615 which is a larger 26hp tractor. The 26hp 2615 tractor is a much bigger tractor and much bigger backhoe, but has basically the same digging strength as the smaller Kioti.
As far as the review, I too cannot climb some hills in high gear, but it's HIGH GEAR and not made for climbing hills. I use for travel only and can go 11mph, those others can't. It would be nice to have a three gear range, but unneccesary with a small HST in my opinion. If I need to climb a hill, I use low gear. Plenty of speed and can climb a vertical wall until the backhoe hits the ground.
Murph, if they quote whatever they are replying to, then it can't be changed at a later date.
   / Choices.....
YES, comparing the two CK20- 2415.
I think something is odd the 2710 which is the 1710b (I thought) has the same numbers as the 3710. I just used those numbers. I hit specs it took me to these number in PDF. It looks like the 2415 can only use the 1710b which has less capabilities.
Confusing??......the 2710 which is used on the 2015 has more ability.
The TYM is now back in the picture an out of state dealer came up with some fairly good numbers. This class of tractor is really competitive and the incentives are all basically the same. TYM has the BEST warranty 5yrs - 3 bumper to bumper thats impressive. I'll hopefully get a test drive today or tomorrow.
If the ck20 had a tad more pto HP this would be an easier decision. Does the 5-7 more PTO/ hp of the other two make much difference as far as running attachments?
Such as a log splitter or post hole digger or a wood chipper?
   / Choices..... #15
That is if they quote? Some people don't quote. I guess I never really thought of it but I don't know of a forum site that has a continuous edit feature.
murph
   / Choices..... #16
I doubt the 5-7 PTO HP differance will have much affect on the log splitter.
But it will make a big differance in attachments like the wood chipper, brush mowers or finish mowers, rototillers, Etc.
   / Choices.....
Thanks guy....
I know the size of the attachments make it a difficult question, but the 5-7hp seems to allow for more options.
Unless the TYM blows me away then its the Kioti CK20 GD TLB. I'll need to justify the 2500.00 difference. I know it(TYM 273) has the best capability anyone know about resale for each company?
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2016 JLG T350 PORTABLE ELECTRIC MANLIFT (A52706)
2016 JLG T350...
MILLERMATIC 251 W/LEADS (A55745)
MILLERMATIC 251...
