Buying Advice Choosing between BX1860 and BX2360
   / Choosing between BX1860 and BX2360
Searching is over! New BX2660, FEL and 54" MMM are on the way. Will find out tomorrow if they can squeeze in a delivery by the end of this week.
X500 goes back to the JD dealer tomorrow.
Will post pictures once the new machine is here.
Paul
   / Choosing between BX1860 and BX2360 #24
Paul
Congratulations Paul, that was the decision we made except for the deck and love it more every year. Larry
   / Choosing between BX1860 and BX2360 #25
Well congratulations! You went all the way to the other end of the BX spectrum. That should give you that rear PTO hp for a chipper as well as help with the ground engaging implements. Let us know if you wind up needing some ballast with that ground engagement; I have some inexpensive ways of using barbell weights purchased on the cheap!
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
