Cistern Tank Installation
   / Cistern Tank Installation
Tank lowered down the hole.
Another angle to show the size of this monster.
I called our local "Aquaman" he delivered 1700 gallons of mountain water. Took him about 15 minuets to pump it all in.
Here are the hose connections - no leaks /forums/images/graemlins/cool.gif
Water lines going into basement
Finally - a shot of my lovely wife backfilling. She was the photographer of the project, the master dirt mover form one pile to another, Tank forwoman, & Chief refreshment provider.
Now She wants to know if we need to move any more dirt, She really likes that Jinma (me too).
LAST ATTACHMENT - PROJECT DONE /forums/images/graemlins/smile.gif
   / Cistern Tank Installation #17
Wow, great project and terrific photos. Very helpful. I was thinking of putting in a cistern to collect sump pump water and use it for watering trees and the way back yard. Probably a bit smaller!
Thanks for posting this.
Cliff
   / Cistern Tank Installation #18
nice pics. looks like you had fun, and a great helper/camera woman /forums/images/graemlins/smile.gif
   / Cistern Tank Installation #19
Just a curiosity question -do you have a vacuum breaker on the line between the well and the tank to backup the check valve to prevent siphoning back to the well?
</font><font color="blue" class="small">( -do you have a vacuum breaker on the line between the well and the tank to backup the check valve to prevent siphoning back to the well? )</font>
I did not install a vacuum breaker because the way the system is plumbed, the well water is a separate circuit. There is a 24 volt solenoid valve that turns on / off a water valve from the well pressure tank that goes into the cistern tank. When the valve opens, well water is allowed to flow (under pressure) into the cistern tank through a check valve, when the solenoid valve closes there is no back flow from the cistern tank back to the well pressure tank
1. Because the solenoid is closed and
2. There is a check valve.
I think this should be sufficient protection? Besides that, the water in the tank is from the well anyway, they are one in the same or is this not correct thinking?
Basically the Cistern tank is like a huge capacitor, well water fills the tank very slowly 24/7 then we pump the cistern water through the house plumbing. Water is filtered from the well before entering the cistern tank then it is filtered again as it is pumped out of the cistern tank into the house Then it goes through a water softener and for drinking / cooking water we have a Reverse Osmosis system in the kitchen.
CASE TV450B SKID STEER (A52705)
CASE TV450B SKID...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
2017 TAKEUCHI TB240 EXCAVATOR (A52705)
2017 TAKEUCHI...
2016 Case 821F Articulated Wheel Loader (A55851)
2016 Case 821F...
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
2021 Toyota Corolla LE Sedan (A55758)
2021 Toyota...
