CK 30 OIL OVER FILL
   / CK 30 OIL OVER FILL
I swear , drill a sight hole in the dip stick, what a get idea. The more I log on to this site the more I learn.
   / CK 30 OIL OVER FILL #32
I second that! Dang good idea... I know three small engine dipsticks that will get the drill treatment next week when I get home....
   / CK 30 OIL OVER FILL #33
DIRTCUTTER said:
CK30 bh/fel/ My question is what damage if any did I do to the motor.
Very sorry for predicament you found yourself in. As an Engineer I have a solution for "over filing" or "not filling" in engine crank Case. Can have two 1/2 NPT connection at the side of crankcase for low and high condition, put and elbow and nipple piece with a screw in magnetic float and a sealed reed switch. Wire that up in series (normally closed float sensor) to ignition and motor starting circuit. if one or both condition are met the engine will not start.You then promptly scratch you head and say hmmm. :confused: at least you can not kill the engine till you figure out what you have done wrong. My two cents.
   / CK 30 OIL OVER FILL #34
Sight hole in the dipstick. Great idea! Also, for tractor-hyd fluid,
use the colored stuff. I use Chevron 1000THF, which is maroon.
It is extremely difficult to read a clear fluid level on a dipstick or
site glass.
   / CK 30 OIL OVER FILL #35
Case makes hytrans oil for their machinery that may cross to our tractor's requirements for hydro fluid. It is red like ATF.
2013 Great Dane 53ft T/A Reefer Trailer (A51692)
2013 Great Dane...
2012 MACK GRANITE (A53843)
2012 MACK GRANITE...
grapple for mini skid steer (A53421)
grapple for mini...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
