CK 30 OIL OVER FILL
   / CK 30 OIL OVER FILL
I swear , drill a sight hole in the dip stick, what a get idea. The more I log on to this site the more I learn.
   / CK 30 OIL OVER FILL #32
I second that! Dang good idea... I know three small engine dipsticks that will get the drill treatment next week when I get home....
   / CK 30 OIL OVER FILL #33
DIRTCUTTER said:
CK30 bh/fel/ My question is what damage if any did I do to the motor.
Very sorry for predicament you found yourself in. As an Engineer I have a solution for "over filing" or "not filling" in engine crank Case. Can have two 1/2 NPT connection at the side of crankcase for low and high condition, put and elbow and nipple piece with a screw in magnetic float and a sealed reed switch. Wire that up in series (normally closed float sensor) to ignition and motor starting circuit. if one or both condition are met the engine will not start.You then promptly scratch you head and say hmmm. :confused: at least you can not kill the engine till you figure out what you have done wrong. My two cents.
   / CK 30 OIL OVER FILL #34
Sight hole in the dipstick. Great idea! Also, for tractor-hyd fluid,
use the colored stuff. I use Chevron 1000THF, which is maroon.
It is extremely difficult to read a clear fluid level on a dipstick or
site glass.
   / CK 30 OIL OVER FILL #35
Case makes hytrans oil for their machinery that may cross to our tractor's requirements for hydro fluid. It is red like ATF.
28013 (A50322)
28013 (A50322)
Brushfox HD-78 (A53421)
Brushfox HD-78...
2012 Nissan Maxima Sedan (A51694)
2012 Nissan Maxima...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
