CK25 Delivered Today
   / CK25 Delivered Today
huh? didn't know that. Well I have only been running the tractor at about 1500-1900 rpm, due to the manual stating keep the rpm's lower during the first 50 hrs. I suppose that may have something to do with it?
Thanks Gerard
   / CK25 Delivered Today #12
</font><font color="blue" class="small">( HOWEVER, after today and yesterday of a few hours of use, My hour meter is still shownig 1 hour?? Is something wrong or is this normal? I plan on contacting the dealer tomorrow to get some info.. I would think that their should be at least 2 hours on it by now)</font>
The CK25/30s both have digital hour meters that measure actual time. Something must not be right with yours.
My CK20 does have analog and is based on RPM hours not actual clock time as yours should.
John
ok, here is a picture
   / CK25 Delivered Today #14
</font><font color="blue" class="small">( Hope this picture works )</font>
Try this: After you type your text, check the box below that says, "I want to preview my post and/or attach a file." Then click continue. You will see a browse button. Click that to go to the file where your picture is located, choose that file and click continue. The file needs to be less than 100,000 bytes or 100KB to post. If it's too large, change the DPI, which is probably deaulted at 72, to around 65 or so, and see if that makes it the right size for posting.
John
ok , fixed this one.. didn't realize it was the same as above
another one
last one
   / CK25 Delivered Today #18
Now you're cooking with gas!
I never get tired of seeing pics of any tractors, but the newest CKs are just too HOT. Thanks for the pics.
Have you tried that Leinbach PHD yet? How does it do? Mind sharing the price with auger included?
Thanks again, John
I have dug two holes, and I can definitely throw the manual post hole digger out the window, in about 10 seconds the hole is done. Since I have the 12" auger I didn't dig too many holes. I didn't want the pasture to be what would look like a home to a ground hog, so until I have some posts to put in the holes, I'll have to refrain myself.
Since I got the PHD and auger with the tractor deal, I got a better deal then if I were to buy it separate. $400 for the PHD and auger (plus some extra bribery helped)
   / CK25 Delivered Today #20
</font><font color="blue" class="small">( Since I got the PHD and auger with the tractor deal, I got a better deal then if I were to buy it separate. $400 for the PHD and auger (plus some extra bribery helped))</font>
Thanks for the reply.
For your protection and that of others, please put some type of flaggin in the holes so someone doesn't break a leg, and sue you.
Even if they shouldn't be on your property, you'll be liable.
John
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
(1) HD 24ft Free...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
