ritcheyvs
Veteran Member
ERE: Congratulations on getting your machine back to the "barn." I hoped that jiggling would work for you. If you do this again, be prepared in case the IP jams at some position other than "off." Remember that there still is a piece of broken off gear tooth somewhere which could again jam the IP causing the engine to over-rev. You would need to stop it by starving it of fuel (disconnect or pinch off fuel line) or air. I could probably kill my gear machine with the clutch but you don't have that option.
Your best bet for repair would be a local Diesel repair shop if (a) there is one and (b) they are willing to help. I had an email conversation with Conestoga (link in Vic's email). See this post : http://www.tractorbynet.com/forums/kioti-owning-operating/296793-kioti-ip-repair-option.html?highlight=zexel.
These IPs were a Robert Bosch design for small engines. Bosch is now renamed Zexel, at least for their fuel injection stuff. Zexel licensed this design to Doowan (Korea) who produces the IP for Kioti engines. There seemed to be some sort of license issue where some bonafide Zexel Diesel repair shops would not touch Doowan IPs (sherrym's experience). Others shops had no problem fixing them. As you can read in the linked post, Conestoga found the Doowan part to be identical to their in-stock Zexel replacement. Changing the chipped gear will not change the vertical dimensions between the tappet, plunger, and sleeve (assuming all parts go back in same locations) so there should be no need to re-calibrate the IP after replacing just the gear.
I'll opine again that leaving effected owners hanging out, like with this IP issue, vs proactively helping in the few cases when it happens is the difference between a world-class operation and an also-ran. A little effort on Kioti's part in these cases would provide more good will and reputation than ten times that amount spent in advertising. I suspect this is a Wendell NC policy, not a Korean one. I also suspect a greater percentage of Kioti owners follow TBN than the big brands because Kioti dealers are fewer and further between, especially since the recession. So many Kioti owners get their information here vs just calling or visiting their (non existent) local Kioti dealer.
