CK2610 HST is it the one.
   / CK2610 HST is it the one. #11
I will be joining shortly. After exhaustive research and window shopping, the Kioti was a relief to find.
   / CK2610 HST is it the one. #12
My CK2610 will finally be delivered this Thursday/Friday..... rain or shine I'll be playing in the dirt this weekend :D
   / CK2610 HST is it the one. #13
You've likely found the perfect balance... ;)
   / CK2610 HST is it the one. #14
It's going to be a long couple of days for you. Lol
   / CK2610 HST is it the one. #16
LOL found that telephone pole buried in honey suckle vines that day laying up against that hay barn in the background. Was able to work it out with the forks and found the balance point and just had to stop and take a picture of it. 40 foot pole. Not even sure how much it weights but had no trouble picking it up. Moving it was a matter of slow balanced precision though.
   / CK2610 HST is it the one. #17
I’ve got to think it was darn near capacity. I assume it’s Doug Fir and around 12” diameter. At 40’ long it would be around 1500lbs!! Very impressive!
   / CK2610 HST is it the one. #18
Just curious. What brand are the forks?
   / CK2610 HST is it the one. #19
They also use southern yellow pine for utility poles and since he’s from South Carolina, where that species grows like a weed, I’d put my money on that...your weight estimates are right on though :)
   / CK2610 HST is it the one. #20
Local company branding them at Tiger Implements.
It probably is. The FEL didn't hesitate to do it. Finding the balance point took a few tries of course. And once its rolled back to the back its nearer your pivot pins so the capacity goes up a bit. Im thinking the capacity is around 1000 pounds with this fork on. Just guessing. Pine would be a good guess as well. The pole is probably bigger than 12" diameter on the big end but it tapers all the way and probably is more like 8" on the small end. Im certain its near capacity if not a bit over for sure. But yesterday I pulled a Chevy 2500 crew cab out with the tractor. Didn't even hesitate. Slow and easy in low gear... no issues. Did it with ease.
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
DuraLiner Drop-In Truck Bedliner (A53425)
DuraLiner Drop-In...
2025 MAMMOTH SB-2 2025 SAND BOX TRAILER (A56129)
2025 MAMMOTH SB-2...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
