CK3510 opinions
   / CK3510 opinions #31
Yes, it does. The switch to enable the DPF regen is the one to the right of the hazard light switch in the article's picture of the dash (bottom right of dash). It's covered in section 4 of the owner's manual, and the part # for the filter is F5850-25101.
Ok, thanks. I read the article and was like how could they have gotten by without one.
   / CK3510 opinions #32
This tractor is on my short list to purchase within a year. Dealer quoted me a "cash" price of $26,400 for the HST version with FEL, back hoe, and 6 foot box blade.
Good price or not?
   / CK3510 opinions #33
I paid a couple hundred more for the CK3510SE (FEL+Back hoe), but no box blade. Dealer originally quoted me $2k less for the Std CK3510 with the same setup. A decent box blade is what, ~$900?
YMMV.
   / CK3510 opinions #34
Good price or not?
Haven't personally priced anything since 2014 but based on other quotes I've seen posted here - seems reasonable.
Our older CK35 (gear) was $17.5, add $1k for HST, $800 for a good BB and you're at $7,100 for the BH which sounds reasonable. Now if you factor in any other additional things like filled tires, rear remotes, floor mat, extending 3pt arms, etc. that add more value to the package then I think you're doing pretty good.
   / CK3510 opinions #35
Very confusing to a non tractor owner. I am learning as I go and my short list includes the Kioti or a Mahrindra 1538 for about $2k more.
   / CK3510 opinions
Not a bad price. I paid more for the same setup minus the box blade. I only have a touch over 20 hours on mine so far and am very happy with the purchase. Kioti makes a good machine.
   / CK3510 opinions #37
I paid 26K even for the CK3510 HST, W/ KB 2475L backhoe with mechanical thumb, linked pedals, cruise control and 4010 FEL. I've been very happy with it and use it at least once a week.
   / CK3510 opinions #38
Correction, the other tractor is a Mahindra 2538, 4 wd, HST
   / CK3510 opinions #39
IIRC, the Mahindra 2538 was a bit larger than the CK3510. Gotta watch out with the Mahindras - the lower HP tractors in a series (1500, 2500, etc...) tend to be on smaller frames than the higher-HP models in the same series. It seemed to me that most other manufactures kept the same frame size within a particular series. Not a 'problem', per se, but just something to be aware of. That's why I was originally interested in the upcoming Mahindra 1635 - 35hp on the smaller frame of the 1526. The current 1533/1538 are larger than the 1526, though I think the 2538 is a bit larger still than the 1538...
   / CK3510 opinions #40
Today spent some time sitting on a 2538 and 2638 Mahindra. I am only 5' 10 and found the seating and petal arrangement best suited for maybe someone 5'5 or shorter. Even with walking shoes on it very uncomfortable to lift my feet up and use the foot controls. Seat was pushed all the way back. Felt like I was sitting in a sub compact car with the seat pulled forward. The 2538 was a little better but not by much.
At this point in time going to concentrate on a Kioti 3510 HST but will take a look at a Kubota as well
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
AUCTION STARTS HERE @ 9AM (A52705)
AUCTION STARTS...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A55301)
2016 KBH...
