Claas knotter problem
/ Claas knotter problem #1
Graham93
Belfast
Newholland
I have a claas dominant conventional square baler. It will miss tie around 5 bales per 100 sometimes more. the longer tail of the loop knot seems to snag in the retainer when it should be released this then causes the knot to pull out as it comes off the bill hook. There doesn't seem to be any pattern it could happen at either side. Has anyone ever had this problem before or have any ideas?
/ Claas knotter problem #2
Greetings and F疂lte romhat isteach!
Is the wiper arm in full contact with the billhook foot on the bad side ? If not, bend it until it scrapes the soon to be completed knot off the billhook.
Or, is it a problem with the two ends of the future knot not being brought together ?
チdh m? ort
Thanks for your thoughts. The claas knotter is a different design to newholland etc it relies on the next bale in the chamber to pull the knot off the bill hook there are no scraper arms.
/ Claas knotter problem #4
G'day Graham do you have the owners manual for this? If you do then they have a very good guide to setting up the knotters, we had one with a similar fault last year and ended up putting a new bill hook in it and whilst it didn't cure the fault completely it dropped the failure rate down to about 2/100 bales. If you don't have a manual I can look it up for you when I get back to work unfortunately this won't be until late next week.
Jon
Thanks Jon. I don't have an operators manual but I have the workshop manual so the knotters and needles are set according to it.
ROLLS OF CHAIN LINK FENCE (A64281)
ROLLS OF CHAIN...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2015 Freightliner (A64119)
2015 Freightliner...
2022 EZ-GO ELITE...
