Clamp on forks
/ Clamp on forks #1
First one
Eastbrook, ME.
08' Kubota L3240 HST /cab
Just picked up a set of Clamp on forks from a sm. dealer who said he paid $190 off of E-bay and asked $225 for them. (Clamp on Loader Bucket Skid Tractor Pallet Fork chain Get fast shipping and excellent service. 4000# CAPACITY. FREE SHIPPING!)
I looked them up when I back and found that you can get them for $169.00.:mur:( Everyone , needs to make the cash) I've never used forks like this before and I can't wait to see what I can do with them. First thing is to load up on fence post at the end of the field. Then there is all the blackberry canes i got piled up ,and then.............. I just hope there not cheap stuff thats going to bend up the first time I use them.. They seem to be built good and heavy. I see there are alot of forks out there that are rated for alot less, for alot more money, I'll find out soon enough:thumbsup:
/ Clamp on forks
Just moved 500 pre. treated fence post. There nothing like the QT. at work that we have on the skid steer. Had trouble trying to slide the forks under to pick them up, and found that getting a few on and loading the rest by hand worked ok.
I could see that the roll backs could be back into the bucket more to handle a little more weight .Where my bucket has a cutting edge on it there is a sm gap between the bottom of the bucket and the top of fork( I should get piece to to put in there or it might bend the bucket) They didn't move around as much as I thought they would ,but had to tighten them up once or twice (didn't chain them on) In time if I use them alot I'll be looking into the QT ones.I think with some hands on , and the money I paid, they'll work just fine for now.
/ Clamp on forks #3
I converted mine to chain on.. much better. when using them as clamp on, they would come off when backing up from a pallet, with the forks on the ground. No worries about bending them.. they are very stout. Also welded some more pipe at the pinch, point where they contact the bucket. It was too far foward, on the lip of the bucket. I welded in a piece of 1/2 inch pipe to contact on the flat of the "meaty" part of the bucket edge. You still have the dis-advantage on not being able to see what you are doing like a real pair of forks without the bucket. But the price was right, and having a pin on bucket, instead of a skidsteer QA, this was a viable alternative.
James K0UA
/ Clamp on forks #4
Any other comments on these? I don't need anything fancy, just enough to move some logs here and there and perhaps lift up a large brush pile. The quick attach option is nice and worth the compromise for me.
/ Clamp on forks #5
Get a QA set for your loader...you already have the JDQA. Bucket forks are a PITA comparatively.
/ Clamp on forks
If I had the money for a QA forks, I would have gone with them.
I do like the idea that if I need my bucket to do anything away from the house ,all I got to do is take the forks off where I'm at and then put the forks back on. Your going to have to tighten them up once in awhile ,they will move some .
I had cut trees around the bottom of my blueberry field and used the forks to move them. Took them off and did some de-rocking and worked on the road going along the field .
Only took 5 min. to change from one to the other. I know you can set your bucket right on your QA forks to take with you, but can be a pain to take over rough ground. All depends on how much your going to use them and want to spend .
/ Clamp on forks #8
Thanks for the feedback, I won't use them all that much. I only put about 70 hours a year on the tractor. :ashamed:
/ Clamp on forks
What do they cost? :confused:
Go on e-bay and just look up, QA forks or clamp on forks.
Seen the QA forks for around $500 plus (new)and the clamp on forks for $160 plus( new) look for free shipping thats a plus. The weight rating should be right up there. I've been told to say away from the 1200 lb rating ,but there maybe someone that has them that works good I think the size of your tractor will make the diff. You could always look for used ,could pick up the QA cheaper.
/ Clamp on forks #10
I bought a set of those clamp on forks. They work. They will bend.( I tweaked mine with downpressure because I couldn't see what I was doing) They do dent your bucket. I am ok with them for now, as they have allowed me to do an awesome amount of work, but if I had the money, I would convert to QA and get those forks.
/ Clamp on forks #13
/ Clamp on forks #14
/ Clamp on forks #15
I picked up a set of the $169 forks from ebay last week. I was pretty happy with them when I unpacked them and clamped them on the bucket the first time. Not 100% sure of the 4000lb capacity, but I'm pretty confident my 2320/200CX combo won't do much damage to them!
Haven't had a chance/excuse to use them for too much other than messing around some the day they showed up. Had a pallet of leftover landscape blocks, but it was too heavy for my loader to lift much more than an inch off the ground. Might have been 1000# on it though.
I figured for as often as I need them, and considering the limited lift capacity of my little loader, these clamp-on forks made more sense than a whole separate attachment. They'll take up much less space in the shop when not in use...
/ Clamp on forks #16
I had a 2320 for 3 years, that little guy always suprised me with what it could actually lift! I think we're in the same boat, hard to spend $800 or more on something I'll use 20 hours or less a year.
/ Clamp on forks #19
Capacity is probably good as I have lifted some serious weight. Just watch that you don't get forks tilted down when applying downpressure, It bends the tubes that the clamp screw goes through. Good value though.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
2014 Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
2014 Jacobsen...
1079 (A64280)
1079 (A64280)
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
