clay problems
/ clay problems #31
I have read so many theories about clay over the years. And talked to expert after expert. All of those readings and experts kind of follow the advise in this thread: many different experiences, including some successes and some failures.
One thing in your post struck a theme though. A couple of folks believe that one can 'dig through' the clay so that water can then drain. Well, that might be so for certain places but it never worked for me. I just got more and more clay the further I dug.
I do believe that the soil can be improved more towards loam over a very long period of time. But that will be a VERY long period of time. I don't think that loam over clay will provide a bed for non-clay-loving plants to thrive. The underlying clay is simply an impermeable layer. Some root systems don't even make it through the clay. (Some do very well.)
I have actually seen places where there is loam on top, and clay below, where top watering has 'floated' sideways and comes out somewhere far from where the water was introduced.
/ clay problems #32
Martin, agree "fixing" clay soil is a LONG TERM project. Everything I read to fix most soil issues (for lawns) suggested adding organic. I had our soil tested and it also suggested adding organic.
As a side note, when we had our irrigation well dug, I watched the dirt that came out of the 60 ft hole. It was clay all the way down! What came out once the drill was at the water table level was saturated clay. It was the most yucky stuff; you couldn't cut it with a shovel and when it dried, it was like steel. Fortunately, I was able to use it rapidly as deep fill, so we got rid of it quickly.
Ron
/ clay problems #33
On a very positive note should you ever decide that you want a pond you have all the right materials for the job.
/ clay problems #36
</font><font color="blue" class="small">( On a very positive note should you ever decide that you want a pond you have all the right materials for the job. )</font>
...but don't try to dig the pond with your tractor. /forums/images/graemlins/tongue.gif
I have a pond that's been dry as a bone for two months. I decided to dig out some of the sludge with my tractor. What a surprise. Driving over it was like driving over a huge sponge. When I started to dig, I found out it was about two to three feet of clay down to the original pond bed. Only one problem, as soon as I went down 18" the clay turned to wet pudge. It looked like chocolate pudding and the same consistency.
I spent about three days and got out about 250 yards of silt. It worked me to death and the job is only 1/4 done. /forums/images/graemlins/crazy.gif I found that if I got my bucket full, the top shelf of clay would fail and the tires would drop down to the pudge. I'd have to dump the load and push myself out with the bucket. I could only get about 1/2 bucket at a time. /forums/images/graemlins/smirk.gif
I decided what I really need is an excavator. I also need something bigger than my tractor to handle the spoils. Oh well, it was a good learning experience. /forums/images/graemlins/smile.gif
/ clay problems
Definitely something to be learned over time. Many times we like to think our machines can do "everything", but weight and reach among other things, are a big advantage.
/ clay problems #38
One thing in your post struck a theme though. A couple of folks believe that one can 'dig through' the clay so that water can then drain. Well, that might be so for certain places but it never worked for me. I just got more and more clay the further I dug. )</font>
Martin,
I think your refering to gardening in clay and not building a road on it. But if you were talking about road building, then I wanted to clarify my earlier post, just in case. /forums/images/graemlins/smile.gif
Two things happen in my area when dealing with clay and water. One, the water sits on the clay and seeps into the ground creating a boggy mess. Or as Jim just said, Pudge. The second is when it does rain, the water will run along the surface like it's pavement and create massive rivers in some cases.
When building roads, I don't dig down at all, but scrape off the surface material until the organic material is gone. Then I dig drainage canals along both sides of the road and build up a crown in the middle. Once this packs down, it will support road base rock without anything else. If it's really sloppy and isn't packing down, I've seen others bring in large rock for base, but I'm not in that big a rush, so I let it pack down over time first.
This sounds really basic, but some of the pics I've seen of roads being cleared make me question about how tall the crowns are being built up before putting down rock. Dirt is allot cheaper than rock. Moving tons and tons of it can be tedious, and compacting it is a whole new thread, but you have to have the material shaped properly for everything to work together.
As for gardening with it, you can hate it, or work with it. I only plant plants that will natralize with minimal care and thrive in the soil I have.
Eddie
/ clay problems #39
Actually, not that good for the retaining wall either. Come your hard VT winter that clay will expand like nothing else and try to push your wall away a little more each year. At least have a couple of feet (horizontal) of pervious soil (gravel, stone, bank run) behind the wall, and drain pipes. That stuff is nasty to build around. I've seen pole buildings that go up and down 3-4" where there's clay backfilling the poles, and I'm south of you a hundred miles. Take care, Jim
/ clay problems #40
Definitely, I am talking about gardening.
The message thread was hijacked a bunch of times, and I thought that I'd just jump in since I dislike clay gardening so much! /forums/images/graemlins/smile.gif)
I plan to learn more about clay building so that I am not totally prejudiced against that form of dirt!
I myself am building a straw bale house. In the process of choosing one of these 'alternative' building materials, I took a look at rammed earth among other things.
These rammed earth walls can be absolutely spectacular. They toss some dyes in the dirt as it is being rammed. The dyes create interesting patterns in the walls that are beautiful.
Then I am also reading about folks from Texas who come to enjoy their red clay dirt. Over a period of time the apparently acquire skills at working with that material. Much like you were saying about how to scrape off the loam, put a crown on the top, and then drop crushed rock over all that.
On the gardening side I don't think I will ever totally enjoy the experience. If the clay is dry, you are basically working with cement. If the clay is wet, you are working with stuff that is hard to walk through and sticks to your shovel. Clay mud on your shoes needs to be sprayed off with a pressure sprayer.
etc etc etc
Great thread!
JOHN DEERE 6105E TRACTOR (A62130)
JOHN DEERE 6105E...
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59906)
2019 WABASH...
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
