Cleaning exhaust build up on FEL arms??
   / Cleaning exhaust build up on FEL arms?? #11
I use Simple Green. It's easier on the paint than some of the other methods. I just spray it on let it sit a few minutes then wash it off.
   / Cleaning exhaust build up on FEL arms?? #12
</font><font color="blue" class="small">( I use Simple Green. It's easier on the paint than some of the other methods. I just spray it on let it sit a few minutes then wash it off. )</font>
Careful with SG as it is a st\rong alkyli and can ruin paint, damage aluminum, etc.
regards,
Steve
   / Cleaning exhaust build up on FEL arms?? #13
Thanks I didn't realize that. I have never had any issues with it on the paint, but I will pay more attention to how long I leave it on.
   / Cleaning exhaust build up on FEL arms?? #14
I use Castrol Super Clean, works great, don't let it soak for too long. Removes it all. Works great on lots of other stuff too.
   / Cleaning exhaust build up on FEL arms?? #15
Spray some Simple Green on it and it will come right off.
   / Cleaning exhaust build up on FEL arms?? #16
I agree. Simple green is the best thing that I have found for diesel soot.
   / Cleaning exhaust build up on FEL arms?? #17
Simple green cuts right through that junk and is user friendly. I use it everytime I wash my tractor. /forums/images/graemlins/wink.gif
   / Cleaning exhaust build up on FEL arms?? #18
I added a 1 1/4" copper, 45 deg. sweat street elbow. (pointed down)
Cut two slots 180 deg. apart, and the width of a hose clamp, in the end of the copper fitting that fits over the tractor exhaust. (slots let it compress a little when the hose clamp is tightened. It's a snug fit anyway)
I was going to weld a fitting on, but I wanted to try one anyone could do that doesn't weld.
It works great, all the exhaust goes to the ground now.
I came across your post about attaching a copper elbow to the B3030 exhaust pipe. I did just that, and I think it'll cure the problem of soot all over the FEL and hydraulic hoses.
Thanks?
John Street
Honeoye, NY
   / Cleaning exhaust build up on FEL arms?? #19
Castrol Superclean. I love that stuff. Buy it by the gallon at Kmart and dump it in spray bottles. The purple cleaner melts it right off. You may need to rub a bit for thicker deposits..........chim
Unless you live in Maine, home of the EnvionMENTAList whackos. Can't buy that or oil-based paints and stains.
   / Cleaning exhaust build up on FEL arms?? #20
500 BBL WHEELED FRAC TANK (A53843)
500 BBL WHEELED...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
