cleaning weeds from a pond
   / cleaning weeds from a pond #1
Michelle K linnane
Esperance NY
JD 4103
I used a tractor and chain today and old box spring and dragged it around the pond edge today, it took some weeds, but need to have some one the other side of pond to drag back and forth to get the place they are thick.
But I think it will work well already got alot of the weeds. placed the spings in the water with the forks and the drag it slow with chain.
   / cleaning weeds from a pond #2
Stop weed growth where you need to control it and let it grow in the other spots for fish. This product works extremely well where you put it and will not leach out underwater. It was recommended and sold to me by Fishman here on TBN. It's expensive, but you just apply it with a broadcast spreader and your weed problems are over.
Aquathol Super K granules
   / cleaning weeds from a pond #3
I agree with Jinman in judiciously using chemical control methods. I've seen some disasters in the past with people just throwing out 50 pounds of copper sulfate in their pond. The weeds were gone, but so were most of their fish. All of their catfish perished.
I called a guy I know who spent a lot of time working with the Purdue Extension department specializing in wetlands. He told me that I had the dreaded hydrilla verticillata growing in my pond. Without proper chemical use he advised me that I'd never get ahead of it using mechanical means. I can't recall what he had me use, but it took 3 doses spaced a week or two apart to control my weed problem. I had to be careful to not kill it all at once and have rotting vegetation rob the pond of it's oxygen supply (his warning, not something I knew).
I'm not familiar with the chemical Jinman suggested, but I'm not familiar with many chemicals in controlling vegetation in water. I think the stuff I use when I first see growth is Cutrine Plus. CUTRINE®-PLUS FACT SHEET It too was suggested to me by the same guy. It controls the green looking pea-soup water issues I get sometimes. It's far more "stupid proof" than just using copper sulfate. You can miss on your water volume calculation by quite a bit and still not harm your fish.
I'm not suggesting Cutrine Plus over the stuff Jinman suggested. I'm just mentioning it as something that has worked for maintaining control once I had my heavy growth under control. Good luck!
   / cleaning weeds from a pond #4
I was told that Tilapia fish (which are good eating) will clean the weeds out of a pond in short order. I have not as yet tried them but would rather do that than use chemicals if possible. Any thoughts?
CHEERS!
. . tug
   / cleaning weeds from a pond #5
My understanding of Tilapia and Carp for weed control is that they will help with alge and a small amount of plants, but only on a limited basis. Most of the invasive pond weeds are not affected by any type of fish.
The only thing that actually works is chemicals. Get it done, get it over with and move on with enjoying your pond.
Eddie
   / cleaning weeds from a pond #6
Michelle,
I've got quite a few years experience in managing private fish ponds. Chemicals are my very last resort.
You don't say where you are located, but grass carp are legal and available in most states. You generally need a permit to stock them, but they will keep a pond clean of most weeds. Two to four per acre will generally do the job. They are sterile and cannot breed (or overpopulate). You don't want too many, as they grow huge and live very long and happy lives. They are a lot of fun to watch when they get to torpedo size.
Tilapia will clean up muck and filamentous algae, but they don't generally do a lot for weeds. Also, they are illegal in quite a few states because they can become invasive in public waters should they escape. They have a lot of other good points, but most strains die out at about 58 degrees F.
Lastly, you might just try a few koi. They do a lot of rooting around the bottom. This does two things. It pulls up the weeds, and it adds turbidity to the water, which limits the amount of sunlight hitting the pond bottom. Less light, means less growth. If you've got bass in the pond, just make sure you get koi that are at least 10 inches long so they don't get eaten. Also, if you've got bass, they will keep the koi from over populating.
You might also want to go over and introduce yourself at the PondBoss.com website. There are a lot of really knowledgeable and helpful folks over there who know a lot about pond management.
Knute
   / cleaning weeds from a pond #7
Thanks guys,...Jinman, Dargo,..and Eddie since you have much more experience with this than I, I shall likely take your advice and get it done. Besides, first, I have to figure out how to get rid of the Heron that comes by and takes all my fish "every"time I stock. Don't know how he knows, but will show up the next day "every" time.
They may be protected in these parts, ..(BUT??) I hate to do it but unless there is a better solution,...I'm forced to get rid of the problem!! How do they look on the table with the mashed potatoes and gravy? (Be the longest "drumsticks" ever, I guess?)
Actually Knute,...it was all my 10" Koi that "big-bird" got last time!!! But I'll keep you in mind once we get cleaned up here,...thanks also for the great advice above, I appreciate it.
Sorry Michelle, didn't mean to hi-jack your thread, but WELCOME ABOARD!!
CHEERS!
. . tug
   / cleaning weeds from a pond #8
Greenbo Lake State Park in Greenup County KY. Those hills were fertile and they built a 225 acre lake about 50 years ago. Weeds grew to 10-12' deep! They tossed in the grass carp and those things did more damange than good. They ate it ALL!! In the beginning it was a fine to keep any grass carp you caught, but these days they want them out of there!
   / cleaning weeds from a pond #9
There has been more than just a little research done in the past 50 years regarding the use of grass carp. When I was growing up we bought 55 gallon drums of DDT by the truckload to spray our dairy herd each day before milking. A lot of things have changed in the last 50-60 years, especially in both dairy herd and pond management techniques. Few people today would suggest 10 to 50 grass carp per acre, as they did 50 years ago. There is also a major difference in managing a small pond of a few acres, or less, as compared to keeping weeds and algae under control in a 225 acre lake.
As for keeping herons out of the pond, there are a lot of methods for their control also, but it depends on the size of your pond, and how the edges are sculpted. For instance, on a pond of less than an acre or so, running heavy monofilament line around the perimeter of the pond, about six inches off the ground, will provide quite a bit of control. The herons have great difficulty landing in the water, and they can't step over the monofilament line. Eventually, they give up.
Just remember, if you are going to use Cutrine, or other chelated copper solution, use it only in very small areas at a time. If you try to do a quarter or more of your pond edges all at once, you will likely cause a dissolved oxygen depletion when the algae or weeds die -- killing a large number of your fish. Too much chelated copper can also poison your pond for many years to come, so use it with great care.
   / cleaning weeds from a pond #10
I believe Michelle, the original poster, may be in France. If so, all this talk by me and others of chemicals may be very limited. I just identified with his trying to drag weeds out of his pond as I have tried that in the past. My experience was exactly as his with needing an easier way to move the drag back and forth across the pond. When I bought the Aquathol K from Fishman, my control problems ended. I was able to spinkle it along the shoreline where I launch my boat and totally eliminate weeds in a channel. My neighbor uses Aquathol K to treat around his floating dock and loves it. One or two treatments a year is all that is needed. We both bought 25 lb buckets at over $500 each. If you pay that much for it, you probably will tend to underuse it rather than overuse it. At least that's my experience.
Certainly, the ability to use chemicals differs from country to country and state to state within the US.
Tug, if I could tell you how to get rid of grey herons, I'd do it. I have several that hang around the shallows of our lake and one of my ponds. I don't see them much around the one pond that has very steep banks. I suspect that's why I still have fish in that pond.
   / cleaning weeds from a pond #11
Michelle,
Knute
I also have too agree, chemicals should be WAAAAAY down on the list for ponds. This is the problem with today society, "we want it done and we want it now !!!" Problem is there is no such thing as the miracle cure, it may work now but at what cost later?????????
   / cleaning weeds from a pond #12
   / cleaning weeds from a pond #13
LOL, those "Great Blue Heron" seem to know that they are protected. I used to be able to walk outside and clap my hands and he'd fly off. Then it got to where I had to stomp and shout. Then it got to where I'd literally fire a .22 into a hill the opposite direction. Finally it got to where I could fire a .22 five feet from him and he'd just look at me for a second and go on about eating my fish. :eek:
At 50 yards that .22 could easily hit a golf ball about every shot so he was in no danger of being shot accidentally. Still, I found it interesting that he literally became totally immune to being scared off by the sound of the shots and even water spraying up from a shot a short distance from him. I gave up and just kept restocking my pond until there were more than he could eat. Besides, he didn't seem content with just eating minnow sized fish. No. He had to eat good pound, pound and a half, bluegill.
   / cleaning weeds from a pond #14
In the early 1990's I lived next to a 2,800 city watershed lake that had a significant weed problem after the lake was about 10 years old. The primary weed we had in the water was hydrilla, which grows to about 12 feet. We had numerous meetings with the city about controlling the weeds. We had about 40%/50% coverage where the weeds would mat on the surface. There were numerous people who wanted to put in grass carp, but the fishermen didn't want to do anything because it made for a great fishing lake. Pictures were shown of some lakes that had the grass carp, where once they ate all the weeds from the lake, they ate waterfront grass 5 feet up from the lake edge, ate tree leaves where trees hung over the lake, etc. The lakes that had the carp were very muddy because of no bottom vegatation and the fishing went from good to poor because the small fish had nowhere to hide.
I was initially pro carp, as I sailed a lot, but after seeing the pictures I was totally against it. I later quit sailing and turned into a fisherman. Caught some very big bass from that lake because it was a great fishery. Later, the lake seemed to balance and the hydrilla was not a problem.
   / cleaning weeds from a pond #15
Feeling like a small fish in a big pond here!
but same problem. Had a small hole dug at
a spring 2 years ago which gives a lot of water
year round. The pone ended up about 25' across, and
maybe 6' deep in the middle. I have tried manually
removing the chara (skunkgrass) and that is very time
consuming. Now, there is a grass that grows tall, and
by now it's got a seed head on it, about 2' tall above
the water. I would like to go back to when the pond was
new, with visibility into the water, but there are about a
dozen frogs that seem to call it home. (the kids love
to watch them)
would these chemical treatments bother the frogs?
at some point I would like to put in a few trout, but if the
water is too filled with weeds, we'd never see them.
any thoughts?
   / cleaning weeds from a pond #16
Well yes, most of my banks are fairly steep especially along the levy, (I have to use the word "levy" as the other darn word always gets censored), but the area where this Great Blue likes to stand is the shallow area leading in from my silt-pond. I have tried artificial herons and a plastic owl,..in vain.
However, the idea of a trip wire along the shore sounds worth trying. The darn bird resides most of the time in the river just a quarter mile south where he has a wonderful seafood menu from which to choose. Perhaps he just comes to check the local fair?
I appreciate the thoughts and suggestions, and yes I hate using chemicals if I have a choice!
I do use Round-Up once a year to control the cat-tails, bull-rushes and large weeds that have dominated in the past. Spraying on the green growth as it rises above the surface kills it right away(couple days) but it won't affect any weeds "just" below the surface or sitting "just" at or below the surface. It doesn't seem to affect the frogs or other organisms. I spray from my pontoon boat and have accidentally sprayed the odd frog.
Round-Up works very well and I am very stingy with it.
I have a lot of weed growth that stay just below the surface. I'm considering a grass carp or two for a brief time to clean things up a bit as its "almost" to the point where the grandkids, (and me) hesitate to swim.
Oh yes J.J : ...we used to use those cannon many years ago, called them "Cherry-Bangers" back then for use in keeping birds out of the orchards! I think you can get an electronic one now that fires through a speaker but although my neighbours aren't close, it might become a nuisance as they tend to be quite loud, but THANKs anyway JJ.
Thanks folks for all good thoughts and suggestions, and you too Michelle.
CHEERS!
. . tug
   / cleaning weeds from a pond #17
This post is very interesting to me. I have a 2 year old 2 acre pound that I built and stocked Blue Gill, Channel Cat and Bass about a year ago. The bass are doing very well based on growth. They were about 1.5 inches long when stocked and now I'm seeing them around the edges that are about 7 to 8 inches long chasing all the minnows. The only issue I have is some sort of vines are beginning to grow at the waters edge vigorously and spreading on top of the pond. At this point I actually like the plants so the minnows have a place to hide but concerned about the future. My question is should I pull them up or leave them so the fish have some protection?
Second question: I built a second pond it's around an acre and 20 feet deep at the deepest point. We had a 10 inch rain a few months back and the pond filled to the top. Now it's about 30% full and going down as I type this question. A more seasoned farmer informed me that bottom was dug out of the pond. Basically we dug too deep and the water is seeping through. Anyone had this issue or heard of this before? I'm new at building ponds as you can tell by my questions. :D
Thanks, Bob
   / cleaning weeds from a pond #18
Thanks, Bob
That's completely based on your area and your particular soil conditions. Around me there are some places where you hit rock 18" down. Where I put my pond (about 1 1/2 acres) there was a natural spring that kept things mucky and I dug down just over 20' deep in a relatively large area and was still digging pure gray clay. For a general rule of thumb, if you dig and hit sandstone or any type of rock, your pond will leak. I have about a 5 acre lake on a couple hundred acres of land I bought a few miles up the road that is 25' deep and empty a couple days after a flooding rain. They kept digging until the bottom is pretty well all rock. I need to fill about 18" of heavy clay soil in the bottom and till in some bentonite to stop it from leaking. They spread a couple thousand pounds of bentonite on the bottom a year or two before I bought the property, but it was a complete waste. Bentonite has to be tilled in with some heavy clay soil to work well.
Good luck to ya!
   / cleaning weeds from a pond #19
tugboat-2,
Unless they have changed the properties of Round-Up, it is not allowed in ponds, lakes, rivers. etc. Nor on banks where th run off will enter the water. I believe the correct weed killer you should be using is called Rodeo, and there are several more. Here in Florida, as a landscaper, the [ Round-Up police ] caught me using it without a license and threaten to fine me. Supposedly you can get away with spraying Round-Up if you use the customers tank. It has to do with who has a license to apply chemicals.
   / cleaning weeds from a pond #20
u could get some geese ,if it is cattailes in your pond the geese eat the roots .
large capacity skid steer bucket (A56857)
large capacity...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
2012 KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
2012 KOBELCO...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2023 CATERPILLAR 120 MOTORGRADER (A60429)
2023 CATERPILLAR...
43023 (A59228)
43023 (A59228)
