Clear Thousands of Acres of Brush in No Time With This One Weird Trick
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #31
Mine are Oregon. There are bunches of others like on Amazon. You can drop it top down on berry vines and such- mulches them to bits.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #32
I've got a green machine that is still running strong and starts with two/three pulls- it has the blade on permanently. I do hit rocks so.etimes and sharpen the blade when it no longer cuts like butter. All I do is follow the original cutting surface.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #33
That's the one. I got the 10" silver 120 tooth blades.
I use the red Renegade, good for heavy brush and grass, since I have Stiltgrass on the trails due to deer tracking the seeds around.
I use a Stihl FS110 with bicycle handles and the brishcutter blade cover (It's metal and replaces the plastic one from the weedwhacker during use.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #34
I take used 10-12" miter box carbide blades and punch the center hole out with a 1" die on the ironworker to fit the arbor of my very old Sthil FS 90.
been doing this for over 10 years and I have lots of rocks. In fact many of the saplings and small trees are growing directly against a rock and too close to get with the tractor. I've "brushed" rocks with the blades plenty of times and they are surprisingly durable.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #35
I have a head on my Stihl FS350 with four free swinging nylon blades. Just like a mini bush hog. Works great and these blades will last an entire season.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #36
I have a DR Trimmer and use the round chain saw blade. You can sharpen the blade.
However; the blades are pretty expensive I hope one of the blades shown on here will work on the DR. and save me a ton of money.
It really works good on Privet hedge and small (3") trees.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #38
1000+ Trees, 4 Hours, 1+ Acre Cleared with a Brush Mulcher, (y)
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #39
Don't laugh but I can do plenty of damage with my sawzalls. Blades are cheap, rocks and sand don't matter, Juniper won't dull blades out after 5 cuts like a chainsaw. Between a chainsaw for notch cuts on bigger trees, my DR hog for chomping on relatively flat rock-free ground, sawzalls are pretty darn versatile plus you can cut from underground if you want a 'now you see it now you don't' stump free pasture.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #40
A sawzall on a stump root is a great idea. I was using a Maddox when I was doing stump work before the advent of battery powered sawzalls, and that's hard work.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
1770 (A58375)
1770 (A58375)
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2014 VOLVO EW210D MOBILE EXCAVATOR (A60429)
2014 VOLVO EW210D...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
