close call
/ close call #12
Depending on your exact tractor model it will look something like this --
Yanmar Tractor Parts: PTO SAFETY SHIELD _
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Thanks Aaron for the link . I,ll Probablly order one as well . I Just checked out Your Site, Very Impresive & most Helpfull . Mine is a Baby one YM1300D . I Also see You have Manuals as well I,ll Probablly be Needing one on service & parts as well Along with some parts for Repairs I may need to do .
Starting with the Leaking Steering knuckles on both sides that the gear oil pours out , I,m assuming Maybe just needing seals ? Thanks again. Looking forward to doing Buisiness with You. Bob
/ close call #13
cowboy,
stand next to the front wheel on your tractor and push on the top of the wheel/tire. If you hear/feel a "clunk, clunk" then you probably need more than seals. unfortunately that is probably the case. You probably need some bearings too. Usually the seals go out because the bearing is loose or shot.
Mike
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
150 Gallon Saddle Tank (A60463)
150 Gallon Saddle...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
