Clutch on HST
   / Clutch on HST #11
I would rather have a clutch & not need it, than need a clutch and not have one. That was the only aspect of my B3030 i did not like, no clutch pedel.
I am curious what you use a clutch for since we have similar tractors though mine is the older 30 Series.
   / Clutch on HST #12
It is a quick way to kill the PTO if your used to haveing a clutch.
   / Clutch on HST #13
I was glad I had a clutch when I bush hogged a cut-down ~5" diameter tree trunk I couldn't see laying down in the tall weeds (on my new property I'm unfamiliar with) that was jarring the absolute h3ll out of the rotary cutter & even the tractor. My first reaction was to push the clutch in, which worked well.
I now try to also make sure my right hand is ready at all times to quickly lift the cutter with the 3ph lever.
   / Clutch on HST #14
At work we have a one year old 40 something hp Kubota tractor. Sorry I don't know the model. This tractor has an HST transmission. I don't run it very often, but when I do I always wonder what purpose does the clutch serve. I'am sure there is a reason for it to operate this tractor properly.
Thanks, eddy
Eddy, there were two recent threads about this topic you might be interested to read:
Clutch on HST - TractorByNet.com
http://www.tractorbynet.com/forums/...ut-hydrostatic-transmission-transmission.html
   / Clutch on HST #15
I am use to operating tractors on which pushing the clutch doesn't effect the PTO, so I am use to disengaging the PTO lever and raising the 3 point.
I drive several different tractors, so I do what works on all of them. If I try to change now at my age, I may just wind up staring out the window while my tractor comes apart:eek:
   / Clutch on HST #16
I use it to start up, shift ranges, engage 4 wd, engage pto,etc.
   / Clutch on HST #17
I now try to also make sure my right hand is ready at all times to quickly lift the cutter with the 3ph lever.[/QUOTE]
Thats a good habit, i do the same thing unless its a field i know by heart.
   / Clutch on HST #18
City of Lakeland (A51691)
City of Lakeland...
Engel 20' Boat (A50121)
Engel 20' Boat...
1274 (A50490)
1274 (A50490)
