Clutch slipping on hills New Holland TT75A s
   / Clutch slipping on hills New Holland TT75A s #1
magilou
moneta va
New Holland TT75A
How do you repair a slipping clutch.
It's fine on flat ground and doesn't
Slip at all but going up a hill and it slows down.?
   / Clutch slipping on hills New Holland TT75A s #2
Adjustment or replacement
   / Clutch slipping on hills New Holland TT75A s #3
It's almost certainly out of adjustment. Without an owner's manual, follow the linkage from the pedal. Eventually you'll come upon a place to lengthen or shorten the linkage, which is done by turning clockwise, or counter-clockwise a nut with likely, a lock nut, on a threaded rod. Turn in a direction that creates more resistance. You want to do this sooner, rather than later. It's likely the clutch is slipping, and you can't feel it. Slipping clutches wear out quickly.
However, based on your description "it slows down" - what should slow is the movement of the tractor - not the engine. Engine speed should remain constant if the clutch is slipping
   / Clutch slipping on hills New Holland TT75A s #4
Does clutch pedal have at least an 1 to 1.5'' free travel?? If no pedal free travel attempt to adjust clutch pedal linkage
   / Clutch slipping on hills New Holland TT75A s #5
Problem is, with a dry clutch, once they start to slip, it won't be long before you will be splitting the tractor and replacing it. Why I prefer a tractor with a hydraulic shuttle as there is no clutch in the bellhousing to slip.
2016 Ford Focus SE Sedan (A44572)
2016 Ford Focus SE...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A46877)
John Deere 6105E...
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
Godwin CD100S Dri-Prime S/A Towable Dewatering Pump (A44571)
Godwin CD100S...
2015 Ford Explorer AWD SUV (A44572)
2015 Ford Explorer...
4Yd Dumpster (A44571)
