Coffee question
   / Coffee question #31
I have a coffee plant growing, i bought it from a seed company (cant remember which one). its growing great, survived the winter near the woodstove and is doing very well. Ill move it outside soon. Once i get beans from it i can roast them in my toster oven and then blender them.
   / Coffee question #32
A coffee snob!
Is it snobbery to quietly gloat that I can get much better single source coffee beans than any blend sold in my supermarket? And at a lot cheaper price.
Is it snobbery to rejoice that my beans are never more than seven days since roast and three minutes since grind?
Is it snobbery to have clean brewing pots and filters rather than pots washed once a week?
Is it snobbery to use a better brewing method than Starbucks or dunkin donuts uses?
Is it snobbery to make a cup of coffee that is better tasting than in Starbucks or Dunkin Donuts and at a much cheaper cost.
Okay then, I'm a coffee snob.
By the way, the common civet is a weasle like native of the far east. In vietnam they call it squirrels. The civet eats the coffee cherry and can't digest the seed (coffee bean) which passes through its system. The beans are sorted, examined and cleaned and sold as Kopi Luwak in Indonesia. World production is 200 pounds per year and the majority of which is sold in Japan.
I've only brewed it once and found that it had an intense earthy taste with overtones of chocolate that occur in the back of my tongue. Very good. I now have only 425 grams left.
Don't get me started on espresso.
   / Coffee question #33
That is funny.
Those commercials for pills to treat "Restless Leg Syndrome" came out. As soon as they did, I had restless legs.. Power of suggestion. I quit drinking coffee after 1300. Went away. Curse those commercials!
There are guys that I work with that won't touch it after 10am or they cant sleep at night.
   / Coffee question #34
I made a double espresso last night and ..
it was really quite tasty except I should have used eighteen grams of coffee instead of seventeen grams and it should have been ground about one-half click finer in a grinder with flat burrs and the humidity in the kitchen was about three percent higher than the day before and the flavor balance was a little too far toward bitter and was lacking some of the chocolate taste and fruity overtones I like and I noticed that the creme was about three millimeters thinner than last Monday but the pull would have made a great ristretto if I had stopped at twenty-three seconds instead of going to twenty-seven seconds since the crema wasn't a rusty-colored as it should be and the water temperature was about one half of a degree too hot at the beginning of the pull and about a degree too cool at the end of the pull but stability was good in the middle thanks to me PiD control and possibly it would have been tastier if I had brewed it in my press pot or my vacuum brewer but I should have taken that Sumatran Mandheling in my home-roasted blend about six clicks further into second crack and maybe it should have been post-roast blended and I think that three days rest is a little too long for this blend because of the dark-roasted Yemen Mocha I use and I'm going to tamp to thirty-two pounds instead of thirty-three pounds with my next double shot because that worked well last week and maybe I should try one of those stainless steel convex tampers instead of my flat aluminum tamper and I really need to get a triple basket and I think it's time that I move up to a rotary pump model or at least one with a heat exchanger although I have had my eye on a new four-group commercial machine for some time now. but seriously, other than that I was the best espresso I've ever had!
If you think I'm obsessed, you should meet the rest of the group in alt.coffee.
   / Coffee question #35
WHEW!!!!
I've learned that if you can't read an entire sentence without stopping for a coffee break, then that sentence needs some periods in it. :D :D :D
   / Coffee question #36
WOW! Seriously dude, start thinking of reducing your caffeine intake!
Chuck
   / Coffee question #37
Years ago I would get fresh coffee beans from a local market and grind it. Usually Costa Rican, Guatamalan, or Kenyan. The problem was that the store was not very consistent in getting a supply nor was the coffee itself consistent.
So I joined THAT coffee club. Which was good for a few years. The price was comparable and quality consistent. Got really hooked on Kona. :D
Then the club got expensive and quality went downhill....
Started drinking Folgers Gourmet. :laughing: Been drinking it for years. :licking: Price is right too! :thumbsup:
I bought an expensive Cuisinart coffee maker years ago when my old one finally died. At the time the Cuisinart was the only one with a metal coffee pot. This thing will grind the beans for you and brew the coffee when the timer goes off. :confused2: I gave up grinding coffee years ago so I never used that feature. Just wanted the stupid metal coffee pot. :D
The Cuisinart makes good coffee. The coffee maker does make a difference. Over the years I have taken my coffee, sugar, and WATER on vacation to make coffee. And it does not take like home. :p The only difference is the coffee maker. Next vacation the Cuisinart goes with us. :laughing: Usually on vacation I drink what they serve at the resort eatery but next trip the restaurant does not open early enough for me so I have to make the coffee in the room. :)
I hear the presses are the way to make great coffee but I don't have that much time in the morning to be messing with creating a perfect cup of joe. I get the coffee maker loaded with coffee, sugar, and water then press the go button. :laughing:
Later,
Dan
   / Coffee question #38
+1 on dmccarty's reply - I think a really good cup of coffee can be made with fresh,decent coffee and a good coffee maker.
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
ADS Bulk Seed Buggy (A59814)
ADS Bulk Seed...
20704 (A55853)
20704 (A55853)
2005 JOHN DEERE 160C LC EXCAVATOR (A59823)
2005 JOHN DEERE...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
