Cold Start Blue Smoke rehash
   / Cold Start Blue Smoke rehash #31
I already tried that and sent the entire chain of emails back to him showing the entire conversation. His reply was "Give me a credit card number. I'll order the hose for you and shipping is $30.00. Kioti told me that I need to bring my tractor there for the hose replacement under warranty. If you read my other posts you would see that a 60 mile round trip for a hose change with a trailer that I don't have yet is out of the question. I will do a lot of searching for a new dealer if I ever need warranty work. I agree on the block heater versus a hose type. I'll make sure not to puncture anything internally. I'll probably drill the plug, if possible, and use a dent puller to remove it.
I read them all on the way to this one. I saw what you wrote in every post to date. I get the trailer and mileage thing, but the manufacturer and dealer are within their rights and obligations under warranty to require the tractor be at a dealership for warranty work. IF they want to make exceptions, it's their choice. Sometimes they will make exceptions for goodwill.
There is a big orange sticker under the hood of both my first and second DK-40 Kiotis stating that ALL transportation charges are customer's responsibility.
Your trailer issues/proximity are not their problem, their yours.
I was well aware of all of that prior to contacting Kioti. Regardless of that, this dealer still stated to me that he would order the hose and ship it to me under warranty. He failed, then when called on it, he said I need a credit card to order the hose + $30.00 shipping. That put him in my book as a man that can't be trusted at his word. That is where I will leave it as far as this dealer is concerned.
   / Cold Start Blue Smoke rehash #33
Jim, regarding the smoking issue, I'm pretty sure that was a fueling issue. Wasted cold fuel will tend to be lighter, not black., a color that would tend to lead you to believe that it's oil. Could also be not enough fuel. Cold engine smoke isn't as black and white (pun not intended) as is with a warm engine. That said, about the only way you'd see burned oil would be because the engine is exceedingly cold- rings aren't sealing up yet: this just happens, though it really shouldn't happen to any meaningful duration and should only be if it was insanely cold. Can't recall what oil Kiotii is recommending, but I run 5w-40: if it were a colder climate I'd be reaching for 0w-40 (it's available here, and if it weren't much of a cost differential I'd run it- always better going with a lower cold rating).
Sorry if I missed it, but did you replace the fuel filter? If you get enough moisture/water you'll collapse the filter. Some things like this the computer really can't decipher, so it'll be allowing for an increased amount of air while there's really not enough fuel to match (that would tend to involve the turbo, but perhaps there's another mechanism in play?). Total extent depends on how much water/moisture; could collapse a little, or if could be a lot. I haven't changed my fuel filter after I had what was probably a gelling event, probably should have; but, like with you, I did not experience any further problems: I did, however, drain the filter, via the lower drain when doing my 50hr service, and I do seem to recall that I got a fair amount of water (after watching so much various fluids coming out of my tractor during this service I cannot say for sure what it was:eek:). In my case I am pretty certain that I had a blockage at the fuel tank outlet, as I blew back through the line and felt some initial resistance (as though it was an ice pellet); my fuel was summer fuel- I'm a bit new to on-site fuel storage and handling; last fill-up was before fuel change-over and I had no thoughts about all of this at that time, and all the way up until I started to troubleshoot my starting issues).
And as has been mentioned, it could be injector issues. I would make sure that this is all documented such that Kioti is aware of it. I have heard of injectors being replaced; what the issue was I cannot recall.
I'd hope that you didn't totally burn the bridge with that dealer. My dealer wasn't so great at first, but I've made it a point to force a better rapport: I'll suffer high fluid charges just to make sure I'm helping them from being crappy due to financial difficulties. I'm happy to report that things have been a lot better: I also replied to Kioti's new owner survey- I recognize that this is all a combined effort and that it is good for everyone to work together. If I get another survey I will be, as it currently stands, responding more favorably.
My dealer picked up my Kioti twice in order to deal with some issues (cab leak and a mal-constructed loader), on their dime. I believe that it was stated up front that they'd be good with this as long as it within a short period of time after purchase (meaning that it was most likely a new manufacturing issue- defect). As I understand it, ANY recall means that the factory foots all costs (which would also include travel time and or hauling costs).
I did replace my fuel filter yesterday morning when it was 9 degrees out again. I figure I have nothing to lose. I put 5.2 hours on the tractor yesterday without any issues chipping brush and hauling wood around. I started it up tonight to swap the chipper out for my grader blade as we are about to get a possible 2 feet of snow. The tractor fired right up and ran great until I pulled the loader bucket and a bolt fell out. I'm going to make another post on this issue and another one on converting a Baldwin filter for the water sensor. You previously asked me what size rototiller I had. It is a John Deere 4 footer that that I picked up for $100.00 when I had my Cub 7275.
   / Cold Start Blue Smoke rehash #35
Ha ha, well I guess the NXes wouldn't have a problem running a four-foot rototiller:laughing:
I'll keep an eye out for a new posting: I know I need to check all the bolts on my loader- I don't, however, have anything that can measure over 150 ft-lbs., so anything out of this range I'm kind of stuck hoping it's good enough.
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
