Cold Weather Starting
   / Cold Weather Starting #11
Throw a tarp over the tractor and put a small electric heater under it till you get the block heater installed.
Egon
   / Cold Weather Starting #12
Dave...... glow plugs are like light bulbs.... they either work or they don't. Thirty seconds isn't a long time for a diesel of your vintage, and neither is the second or third trying to start before running, excessive considering the vintage of the tractor. I would say that it is normal from my experience. My 1963 Mercedes took 5 or 6 tries before it would fire up in cold weather, and my 1987 would start on the first try every time. Diesel engines have come a long way in the past 20 years and it isn't reasonable to put modern day starting standards on a engine that is of your engines vintage. The only thing that I would consider changing is the oil to a synthetic for better start up lubrication. If you had a dead glow plug, you would have a lot more problems starting that engine than 3 tries. There is a good chance that one defective glow plug would be enough to keep it from starting at all at the low temperatures you are experiencing. My BX22 took 3 tries today to start and that was with glowing the glow plugs each time for about 15 seconds. I consider this normal given the -4 degree temperature. When it is 40 degrees, it will start the first time every time with very little glowing necessary.
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
10ft Inclosed trailer (A53424)
10ft Inclosed...
2010 UNKNOWN 16 T/A TRASH TRAILER (A53843)
2010 UNKNOWN 16...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
DUMP HOPPER (A53843)
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2013 FREIGHTLINER...
