Colvert???
/ Colvert??? #1
PBMAX
Platinum Member
Blount County,ALABAMA
NH TC21D
Hey all,Somebodys been busy...While I was gone...Looks nice...
What I need is howmuch churt should I use over the colvert (driveway pipe) for support before I put down gravel and concrete...?It is a 12" round pipe and is 20' in length...I'd also like to add on 10' more to have 30' wide (to span out for turning in and out )so as to have about 25' of concrete with out getting close to the end to ruduce the amount of stress cracks that can pop up over the years for various reasons...Any ideas???
Lil' Paul
Laziness is the Father of invention.../w3tcompact/icons/laugh.gif
/ Colvert??? #2
Paul,
What kind of pipe do you have? If you are using plastic they are pretty strong but I would put about a foot of churt. Metal pipes should not need that much. Go look and the culverts the county has put in for driveways and see how much churt/dirt they use.
/ Colvert??? #3
I sure learn a lot of new words on this forum./w3tcompact/icons/laugh.gif When I saw your spelling of what I always called a "culvert", it reminded me of the fact that folks in this area call them a "horn"; a term I'd never heard used for driveway pipe until 6 years ago, and still don't know where it orginated. And what is "churt"? I never heard that before and don't find it in either of my dictionaries. I've got 3 culverts, each about 20' long, but different diameters; 6", 12" and 20" I believe, and I don't think any of them have more than 6" of dirt on top and I've never had any problems with them, but they're all concrete pipe instead of the metal that's more commonly used in this area now.
Bird
/ Colvert??? #4
PB - I have a closed cell corragated plastic 18" pipe about 20 foot long, with a less than a foot of good back fill over it. Been in the ground little over an year now in an old field road. The lack of fill is due to location. I just had timber cut and one or two trucks that came out with over 90,000 pounds. Not sure what the axel weight would be, but it is sure more than most drives will see. Would guess that maybe twenty loaded trucks came out plus the timber equipment. Just cleaned out one end of the pipe this morning, where they drug some limbs and topsoil into the ditch. The pipe looks great. I really can reccommend it.
/ Colvert??? #5
Paul, I have a 30' by 18" "tin horn" as we call them here. It is made of rolled corrugated steel. It cost $240. THe county installs all culverts for free that are within county road easements so us dummies don't create maintenance problems for them. THey put clay around it then covered the top with about 6" of 3/4 inch crushed rock. I had 4" of concrete put on top of that for my driveway. It has been there three years and has had cement trucks, moving vans, a caterpillar and 14 yard dump trucks go over it with no impact.
/ Colvert??? #6
Paul,
Over the years I used nothing but metal culverts,but after useing the plastic culverts I'm impress. /w3tcompact/icons/shocked.gif
The plastic culverts are tough easy to handle also one can bend them a little plus easy to add on.
How far do you plan to set the culvert into the ground?
I just use good fill and packed it well and no problems yet./w3tcompact/icons/smile.gif
Have a great weekend and stay safe and /w3tcompact/icons/cool.gif
Thomas..NH
/ Colvert??? #7
Paul, here the county installs the culverts if they are on a road. They charge only for materials. Mine is a total of 32 feet long. The last 4 feet are concrete pipe and the center is metal (24 ft). This keeps the end from getting crushed when some truck runs off the end. Cover here is minimal about 4 to 6 inches. If you are going to pave over it, be sure to let it settle through a few rains first.
/ Colvert??? #8
Thomas, do you know what the plastic pipe costs in either 18" or 24" diameter? I'm thinking of putting in a drain to bypass a shop I'm building and sure looking to save any money I can. OF course, it may never rain here again so water may not be a problem. /w3tcompact/icons/frown.gif
/ Colvert??? #9
For PBurns, EddieW and everyone else:
I did some brief comparisons last summer on the different culverts. I believe that this is good information, but nonetheless it is a collection of "opinions" that are worth checking into further.
Supposedly, the new plastic culverts are about half the price of the metal ones, and just a durable (possibly more so). They have the corrugated outside but have a smooth inside so as to allow easier water flow without debris hangup. According to various sources the plastic pipe was slow to catch on initially but was starting to gain a lot of momentum as it proved itself.
How much fill? I was told that regardless of construction that there needed to be at least one foot (minimum) of fill dirt used on top of the culvert to distribute the loads. I've seen metal culverts (estimated to have 6 inches of dirt/gravel coverage) at ball parks cave in with rare vehicle traffic and a compact tractor.
If anyone has information contrary to what I've posted here please be sure and speak up. I've put off building till next year but will eventually be investing in some culverts.
/ Colvert??? #10
Can't remember where I originally found this, but I think it was from some official highway construction guidline document --
"Bedding and Backfilling: Stumps, rocks, frozen lumps, and other debris should be removed from the bedding site. Well graded drainable backfill is recommended for good compaction. The designer should refer to the gradation and backfill specifications of the appropriate provincial highway standards.
Round pipe can be built on a flat sand cushion with rodding and tamping of the backfill around the haunches. Alternatively, the pipe can be installed on a pre-shaped granular base.
Backfill should be spread in 150 mm layers alternating from one side of the pipe to the other, and should extend above the pipe to a minimum height of 300 mm or one sixth the span, whichever is greater."
Note that 300mm is pretty close to a foot, just like I keep hearing everywhere. Think there's a message here? /w3tcompact/icons/smile.gif
/ Colvert??? #11
I am in the process of building a home with a 1300ft driveway and have two culverts. The secret to backfilling a culvert is to use material that packs extremely hard. When the material next to the culvert pipe is hard and will not "give" the culvert pipe cannot be flattened because the sides of the pipe are not able to "push out". Black dirt and clay do NOT pack well and will always result in flattened culverts if driven over with any weight or regularity. My front culvert only has 2 inches of fill on top and has had more than 20 semi trucks and fully loaded concrete trucks drive over it without flattening it. We used a limestone mix that the locals call "CA6" which is a mixture of small stone (1/2 inch and smaller) and fines. This CA6 packs like rock after a couple weeks, I learned this the hard way when I waited a couple weeks before doing a final grade on the driveway.
Hope this helps.
DavidV
/ Colvert??? #12
DVerbarg -
Okay, now you've got my interest! I was still wondering what to use for backfill and it sounds like you have the answer. Not quite clear on the "packs like rock" part, though. You said you waited a couple of weeks before final grading and it was aleady hard. Was it driven on for those two weeks, or did it pack down all by itself? In other words, if I have a load of the stuff delivered, how long can it sit in a pile before I use it? Since I only make it up to the property 2 or 3 times a month, I don't know how long it will take to complete my culvert project.
Oh, yeah -- and is this stuff available from regular concrete suppliers, rock yards or where? And the usual question -- is it pricey?
/ Colvert??? #13
In our area they call it CR6 it is also called crusher run and crush and run to name a few. It can be left in a pile for a long period of time but what happens after a few months the dust--crushed limestone-- will settle some leaving the larger gravel on top, but it won't pack so tight when in a pile that you can't work it. If you did put it down and it ended up rough and you did want to grade it again wet it down first if possible and it will work alot better and easier. Around here we use just the limestone dust for training tracks for the race horses. I just spread 80 tons of it last week for two circle drives the man was adding to his regular drive that I put in a few months ago. It turned out real nice its the first I used just the dust for a drive. One circle goes in front of the house the other circle goes back to his horse barn. Harv here is a link that might be useful to you http://www.rmcpacific.com/toolbox/tonnage.htm
Also something to think about is the lead in side of the culvert. Put stones around the pipe end to help detur (is that correct spelling) erosion and to channel water into pipe. Also a weedbloc fabric is a good idea behind the rock.
Gordon
/ Colvert??? #14
Harv,
It packs like rock when it is driven on and rained on. The water makes the "fines" wash down in and settle in. If it is not driven on it will pack but will take longer, depending on the amount of rain.
Our gravel came from a local gravel pit and cost about $75 for a 20 ton load. Prices vary by season and local demand. A 20 ton load would cover a typical 30ft x 12in culvert in a typical drainage ditch (what exactly is a typical ditch?) in this area. Many people do with only 15 tons. Check with your local gravel yard to see what cubic yardage you get from each ton of CA6 to properly plan your use.
Charges will vary by mileage and you may find it cheaper to use a 3rd party trucking firm instead of the gravel yard trucks. This is especially true when you are a distance from the gravel yard.
Hope this helps!
DavidV
/ Colvert??? #15
Harv,
Oh yeah, be sure to have the load dumped on the culvert. It will save much time (especially if you are still an aspiring Kubota owner).
David V
/ Colvert??? #16
Gordon,
Like that link for the tonnage calculator for gravel. Wish I had that when I was originally doing my driveway. That would have made my budget process much easier and saved much time.
David V
/ Colvert??? #17
Wow!
You guys are a gold mine of information! Paul, you started this thread -- you getting all this?
I had done a fair amount of research on culverts, but I didn't come up with a fraction of the information you all have just posted. I dunno 'bout Paul, but I think I'm ready to start the culverts. /w3tcompact/icons/smile.gif
Thanks!
/ Colvert??? #19
Bird,
Here in Alabama churt is red dirt/clay with rocks in it. The rocks are anywhere from marble size to grapefruit size. It is usually found in the hilly parts of the state. It is used for county roads, driveways, etc. because it will pack almost as hard as cement when it is wet down and compacted. Have you ever heard the song "Sweet Home Alabama" by the group "Alabama" that mentions churt rocks?
/ Colvert??? #20
OK, I get the idea; just never heard the word before. I've heard the group, Alabama, lots of times, but don't remember that one.
Bird
Pittsburgh Heavy Duty Solid Steel Auto Ramps (A59230)
Pittsburgh Heavy...
2014 Club Car Carryall 500 Gas Utility Cart (A59228)
2014 Club Car...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
