s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,548
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
Powder coat done right will not chip off at all. I shot motorcycle frames for years with powder and have yet to have one chip. It is not a cheap process to do right either. The question is "Are you willing to pay for it".
That's not the issue to me (although it is important to the initial quality for sure). The issue with PC is that once it gets damaged and the underlying base metal is exposed and corrosion starts, the PC actually makes it worse and then will start coming off in sheets as the corrosion gets underneath. I have seen this with steel tractor implements and aluminum boat structures like t-tops and seat frames. When I talked about this with a manufacturer at an equipment show once, he explained how paint performs better in this regard, both because of the way that it sticks to the metal and, more importantly, because they can put rust inhibitors and other things in paint that you just can't do with powder.
If you really want to see PC fail epically, take a look at a boat operating in saltwater with PC on some of the structures (which is PC over anodized aluminum). If you don't immediately touch up chips, it's off to the races as corrosion works under the PC. Bare anodized aluminum does not have that problem despite being the same exact stuff.
