ddivinia
Elite Member
You are correct, you can end up with a Electronic PTO on the 5525. The 540E PTO is the economy mode where the engine runs at 1700rpm to get 540 PTO speed instead of having to run at 2600rpm I believe to get the same PTO. It is nice when I have my MX6 on the back vs. the HX15.
You get electronic PTO engagement wtih the 24F/24R trans. One nice thing that comes with that is you can put a training seat in the cab so people can hang out with you. The PTO engagement lever won't clear the seat, but with the switch - that is not an issue.
On my 5525 I would have ordered triple mid and triple rear valves. Mine has dual mid and dual rear. Which so far has been perfectly fine. My HX15 only needs 2 in the rear and I don't have a loader. If I add a loader, I would want the option to put a grapple bucket on it. As far as the rear valves, I can see where on a batwing mower it would be nice to control each side seperately.
I added the highback seat. It just pops in - it is well worth the money.
I have a rear wiper on order. With the mower - sometimes it can be really hard to see out the back.
I also ordered a grill guard. Sometimes mowing corn stalks will get caught in the hood release and also I run over some pretty serious brush and I figure I might as well protect the front end.
The ehitch is awesome.
The adjustable draft arms are really slick.
Overall, I am totally thrilled with the 5525. I have put 29 hours on it in the last couple weeks. I am using it for some larger jobs, so the hour count is really adding up compared to my 4720. I have 59 hours on my 4720.
A 4720 with a cab is going to be a really slick rig. If you notice, the height on each tractor is pretty close. The 5525 is wider, but not by a huge margin. The wheel base difference is signifcant. The clearance is not a huge difference. The 5525 comes down to more power, more weight, and better traction. Of course I could get a cab in the 5525 and not the 4720 but that is in the works.
D.
D.
