Concrete Balast Box Cure?
   / Concrete Balast Box Cure? #1
Racer71
Peyton, CO
Kubota L3400 HST
How long do I have to wait before I remove the form? How long until I can use it?
   / Concrete Balast Box Cure? #2
You forgot to put lifting hoops/rings in it , If it were me ? I would wait at least 48 hours in comfy temps, not freezing temps. Take your time and you will have a "forever weight box" that you and your followers ( son's, grand children )will enjoy for a long time
Ya should date it with your name. all it takes is another layer.
Do It for them :D
Jim
Jimi,
I thought about the hooks but didn't for two reasons.
I don't think I can lift it with the FEL.
I can always put a chain through the top link arms.
   / Concrete Balast Box Cure? #4
Think about this,, You will get a bigger,stronger unit some day. Always plan ahead.
You should be fine for now and you figure a way to pick it up in the future
You can always drill a couple of holes and insert two bolts for lifting
I know I would :D
Jim
   / Concrete Balast Box Cure? #5
Nice Job Racer.
Looks HEAVY!
I would give it as long as possible to cure...several days if not more. Concrete actually takes about 30 days to reach full strength.
   / Concrete Balast Box Cure? #6
You should wait about 7 days, if the temperature has been at least 50dF. Concrete gains about 60-70% of its strength in the first week. JHT
So much for waiting. :D
dillo99 said:
Nice Job Racer.
Looks HEAVY!
It came in at 1,300 pounds. It is transfering about 800 pounds from the front axle to the rear axle also.
One use for this is wheel packing my driveway project. With the ballast block and a full bucket I am increasing the weight of my 4,000 pound tractor by 2,000 pounds!
I plan on using it some tomorrow before I head off to the Chili Bowl. It will then sit for a couple of weeks.
This thing is great! If you want to dig in the dirt get a tooth bar and a ballast box. They work very well together. :)
   / Concrete Balast Box Cure? #10
Hmmm ripper teeth under a ballest box. thinking of a new toy for breaking up red clay.
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2002 Kenworth T300 TMA Attenuator Truck (A55973)
2002 Kenworth T300...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
