DocBob, Pilots say, "Mind thy airspeed lest the ground arise and smite thee!" Floors are like that too. Be careful lest your floor arise and smite thee.
Excellent point about the cost of the envelope or the walls. Even if you paid twice as much for a concrete wall the percent increase across the whole project including land, landscaping, site prep and on and on is not THAT BIG.
Regarding the casting of basement walls... I honestly don't know for sure if I would have any problems, given my use of InsulDrain and the redundant French drains if I had not gone monolithic. Concrete typically develops cracks. Rather than trying to prevent all cracking, nearly an impossible feat, I chose to design so that cracks didn't matter. Plenty of rebar holds the concrete together even with lots of cracking, reducing virtually all cracks to minor cosmetic concerns, unless of course you are using a spray or brush-on waterproofing compound and they you have to worry about it failing at the site of a crack.
My monolithic basement walls are 12 inches thick and have a regular pattern of intentional holes through them from the inside to outside. The holes are because we used "SnapTies (SP?)" as part of the forming method. With Insul-Drain, cracks and holes in the wall do not introduce moisture. My fall back plan if too much humidity evaporated off the interior of the basement walls would be to paint the interior with DryLock. There is NO PROBLEM. I not only do not have visible water I have covered sections of floor and wall for a week with vapor barrier and the covered concrete not only didn't get wet it didn't even slightly darken, an indicator of moisture.
Actually, Davis was a fairly early popularizer (in contemporary US) but wasn't close to being first to build, promote, or inhabit an earth sheltered or "underground" home. As I mentioined in an earlier post, among others, the Chinese took to earth sheltered housing early on and in a big way. There are millions of earth sheltered homes in China. They have entire communities of earth sheltered homes and this didn't start recently.
Davis has some good buildable plans and a good reputation. I'm not knocking that ouitfit. Their family did and is doing much to popularize a good thing and they haven't remained static, evolving over time. They have a lot of satisfied customers. They just didn't happen to be a good match for me or so I thought.
Patrick_G
