Concrete Pad Slope
   / Concrete Pad Slope #21
I think I will go with Eddie on this. I'm the guy that has to keep these " just enough" sewers going. I only have 35 years experience, you others may have more. I have seen many more sewers give trouble because they were too flat. I have NEVER seen a 45 degree down hill sewer clogged. The flat sewer may work on paper, but how do you keep it perfectly flat? There are always dips and sags in the back fill. Every puddle will have solids puddled in it. This falls under "urban legends" the myth busters would have a great time with it.
   / Concrete Pad Slope #22
Well to further the hijack :)
I would never argue with your experience, but I think you are referring to house sewer laterals like Eddie was also.
I'm interested in the municipal sewer system. I do basement waterproofing work and many of the older homes, probably 50% have what's called combination drains in the basement. basically it's a wye off the 4 inch cast iron house sewer under the floor. off the wye is a 4" cast gas trap and then a 4" cast iron back flow valve. the back flow valve is in a small pit in the floor and the sub-floor footing drains spill into the pit and drain thru the back flow valve. So it "combines" the storm water from under the house with the sanitary sewage.
Environmentally it's a terrible system , cause it overwhelms the treatment plant with storm water, some of the oldest streets in the city actually have the catch basins drain into the sanitary sewer, they separate them when they redo the roads where possible.
It's a great system for the homeowners, when they function properly, as there is no need for a sump pump, worry of power failure or water discharging out the side of the house onto the yard.
The problem is because there is so much storm water in the system during heavy rain events, many people living in the lower areas experience sewer back ups. sometimes the back-flow valves are stuck open, but even if they work, they rarely close tight plus when the flap is shut the home's storm water can't get out so the basement floods. Often times the back flow valves are capped and a sump pump is installed
Anyway, I need to be able to advise the homeowners of the possibilities and alternatives based on the risk exposure, so it helps that I know locations and sizes of the street and main sewers in any particular neighborhood. I have the detailed maps.
Sorry kind of long winded here, but anyway maybe that idea of the liquids and solids seperating is an urban legend, but not the almost flat main municapal sewers. Those are often referred to as engineering marvels, and rightly so.
This thread made me dig deeper to further understand the subject, I've always tried to explain to my customers about the way their basement water is handled thru the sewer system, I've always told them that it travels all the way to the plant at a very precise 1%, as that's what I believed.
But that doesn't work, as that's 50+ feet of slope in just a mile, we do not have that much topograhy to work with. So I learned that those large trunk sewers are set at somewhere around 0.1% in the very flat areas, that is an engineering marvel.
Sorry for the long rant, it's just something I'm interested in.
JB
   / Concrete Pad Slope #23
Well to keep the hijack going, we are dealing with old and new tech. I live in an area that probably hasn't had sewers in town but just since the WPA installed them. You are in the OLD section of the country. We don't deal with the topo like you have. We have pump/ lift stations spaced all around town. Our sewers can run however they need to. When they run out of drop they put in a lift station and awaay it goes down hill to the next one. Every time we get a new political group running things they get some grants and they extend the system to take in a bunch of septic systems and away we go again.
   / Concrete Pad Slope #24
Does anyone remember the original question by the OP? Many years ago I helped pour a lot of carports and patios in Florida with my brothers. We always used 1" per 8' for the slope. If you aren't a good finisher you can go to 2" per 8' so you don't have any small puddles.
I poured my driveway 23 years ago. It is 65' long and drops 8" from the edge of my garage slab to the road. I was a little worried it wouldn't drain well enough but it drains just fine.
   / Concrete Pad Slope #25
Oh forget about that pad slope, he got enough good advise :eek:
yeah, in the city it's probably 100 years old in places, took longer to branch out to the suburbs, probably 50-60 years old.
We do have small neighborhood pump stations, they were not put in til maybe 30-40 years ago to service the areas that were still on septic.
My house's sewer drains to a pump station which serves about 30 houses on the wrong side of this little hill, Tiny little fenced in site, pit looks to be maybe 4 ft in diameter, it pumps it up thru what they call a force main to just over the top of the hill. But no pumps on the main sewer.
Sewers came down my street in the late 60's but the former owners never connected, when I bought the house in 2003 I wasn't gonna chance 5 people using a 70 year old septic system, so I connected to the sewer, My freind who is an old school sewer man did it for me, my basement floor is higher than the street so there was not much enginering, he basically just followed the slope of the yard, so mine is probably more than 10% in spots, about 120 feet long.
I never have to worry about sewer back-up, except from my own line.
When we excavated across the front yard we crossed the end of the leach field pipes, they were 4 inch clay tiles set in 2 inch stone, you could see they were perfectly clean still, water had never reached that far. So I'm using that old septic/leach system to handle the roof leaders and patio surface drains in the back of the house, which is very flat.
JB.
Deere 331G (A53317)
Deere 331G (A53317)
Ford 8340 (A53317)
Ford 8340 (A53317)
2014 Chevrolet Tahoe (A55973)
2014 Chevrolet...
48'' ALUMINUM MAN BASKET (A56857)
48'' ALUMINUM MAN...
2017 Jacobsen 3551 HOURS (A56857)
2017 Jacobsen 3551...
78'' SKID STEER BUCKET (A56857)
78'' SKID STEER...
