I received the new-style fan guard on Friday, 6 November, from my dealer. I installed it this morning, 14 November. There is a floor support bracket on the right side of my
BX2350 that is held in place by bolts that are in the place where the right side of this bracket is designed to be held to the tractor's frame.
I did not remove the tires in order to install this bracket.
The HST fan protection bracket is designed to straddle the frame. In order to do that the bracket that supports the floor pan on the forward right side must be unbolted and pried away from the frame enough to allow the bracket to be slid in between the frame and that bracket. (I hope this description isn't too confusing.) That floor support bracket is actually held in place by three bolts, the two that use the two holds in the HST fan protection plate, and one about two or so inches toward the back of the tractor.
If I were to have installed the plate with the right side squeezed between the frame and the floor support bracket, I would have had to shim the back of the floor support bracket to compensate for the thickness of the HST fan protection plate.
I chose not to do that. Instead I decided to simply bolt the HST fan protection plate to the *inside* of the frame on the right side (using the bolts that are already there that hold that right floor support bracket in place) and the outside of the frame on the left. That meant that the bolts on the left side (which I had to supply) actually served to draw the bracket in to the frame (which I supposed I could have shimmed with flat washers, but I did not have time to do that today -- I think I'll correct that tomorrow).
Anyway, it seems to fit well enough as it stands. It's not a BroTek but it is a quarter of the cost.
The process took maybe twenty minutes. My dog "helped" by getting his nose under there to see what I was doing, which meant that without him I could have shaved a minute or two off the twenty. He was wagging the whole time, which left me conflicted sending him away.
Doug
BX2350, and stuff.
