Confused about oil change
   / Confused about oil change
Since you have the used M1 filter now why not hold onto it till you change the oil again and open both filters up and check them side by side?
Good idea. I'll give it a try.
   / Confused about oil change #32
Have an oil analysis done after using each oil filter. May need to run a few to weed out any variables. That's the best way to determined which filter is actually better. Costs you some money for the experiment but you end up with a pc of mind and the results can be shared here for other to use.
   / Confused about oil change #33
I also use my tractor only about 20 hours per year, so I change the oil every 2 years. I try to use the tractor at least once a month though to get the moisture out of the engine.
   / Confused about oil change #34
teikas dad should you open both oem & m1 filter, and also get a (well suggested) oil analysis on each, post results. be interesting to see. cheers
   / Confused about oil change #36
hey teikas dad i would not make any apologies whatsoever in your quest for finding out what's best for your tractor, esp when it comes to oil filtration, etc
people laugh at me all the time because i do the same when it comes to that kind of thing as it applies to machinery in general...great to have this forum where people like to vent their opinions. at the end of the day, you'll know what's best for ya all the best... :thumbsup:
Totally agree! This forum is great for us **** is in analytical guys! :D
Yeah, I know...I overthink and OCD everything.....I'll shut up and get my butt back on the tractor!
Yeah baby your tractor and ride it often and do stuff you never thought of... the pleasures of owning one! :cool2:
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
HYSTER H50FT FORKLIFT (A52472)
HYSTER H50FT...
RIGID TOOLBOX (A52472)
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
