Confused: CVT vs. Hydro??
   / Confused: CVT vs. Hydro?? #11
actually they (NH) has been testing and testing the CVT for the past 6 plus years before they even let it be known they were thinking about the CVT in compacts. The CVT is designed to last at least twice as long as a gear and hydrostat. They put 7000 plus hours on different tractors in different conditions. the chain that is used in the pulley system has a tensile strenght, or breaking point of 7500 lbs. it is designed to be maintence free and needs no adjusting.
The EasyDriveTM CVT emits less noise than a hydrostatic transmission.
Hydrostatic transmissions have an inherent noise due to the use of oil under
pressure to transmit power. This hydraulic noise is eliminated from the CVT,
resulting in a much quieter operating transmission at all speeds. Tests have
shown a 2 dBA reduction in noise compared to a hydrostatic transmission whenoperated under the same load conditions.
- The ability of the EasyDrive CVT to transmit power to the rear PTO whilethe
vehicle is moving is higher than for a hydrostatic transmission. The use of a
mechanical link (steel chain) is more efficient than utilizing fluid (oil in
hydrostatic transmission) for the transfer of power. In a dynamic mode, the
CVT requires less power to move the tractor, due to its mechanical efficiency,
and therefore has more power available to transmit through the PTO. Sincethe
majority of PTO tasks are performed while the tractor is moving (finish
mowing, rotary cutting, rotary tilling, snowblowing, etc) this is a significant
benefit. In a tractor equipped with a hydrostatic transmission, as the travel
speed increases, there is a corresponding reduction in power available at the
PTO, as more of the engine power is required to turn the wheels. In the working
speeds from 2 to 7 mph, a hydrostatic transmission can experience a reduction
in available PTO horsepower from 3% to 7% while the EasyDrive CVT will
maintain PTO horsepower and not experience a drop as the travel speed is
increased.
The EasyDriveTM CVT found in the Boomer 3000 Series is based on a simple
design
that uses variable diameter pulleys connected by a steel chain to alter the transmission
ratio and adjust for speed and power requirements.
How does it work ?
Input power from the engine flows to a set of hydraulic clutch packs which control theforward and reverse direction. From there, the power is transmitted to a Chain Drive
Variator which is used to adjust the transmission ratio, thereby determinig
the speed
of the tractor and its ability to transmit power under different loads. The Chain Drive
Variator is made up of 2 variable diameter pulleys that are connected by a
steel chain.
From the Chain Drive Variator, the power feeds directly into an epicyclical
gearboxthat transmits the power to the rear axle.
   / Confused: CVT vs. Hydro?? #12
sounds like we are getting some inside info-which is good. In my mind, I have a tough time accepting the fact that a chain and variable pulley system is less prone to failure than a system that basically relies on the non compressibility of as liquid to transmit power.
On another point, any reason why Ford dropped it like a hot potato? Also are any big machines going to CVT?
   / Confused: CVT vs. Hydro?? #13
"This hydraulic noise is eliminated from the CVT,
shown a 2 dBA reduction in noise compared to a hydrostatic transmission whenoperated under the same load conditions."
2 dba in noise reduction is MUCH quieter? I beg to differ. 2 dba is almost a nominal difference and when comparing different units the opposite may even be true. My Hydro is actually pretty quiet. If it were 20 dba quieter, THAT would be much quieter!;)
As far as Ford dropping the CVT, that trans was a product of Volvo. I don't even know if Ford still owns Volvo. If they sold Volvo, Ford would no longer handle the unit.:confused:
   / Confused: CVT vs. Hydro?? #14
well i havent heard they are changing the CVT in the compacts. but yes CVT has been in the 125hp up to 250hp for a couple of years now. Awesome driving. really easy and gives the tractor and engine a lot of choices and power compared to a powershift or other
   / Confused: CVT vs. Hydro?? #15
Having owned 2 hydro units(tc35d, tc40d) I can tell you for a fact that my Case Farmall 40 with the CVT is a huge improvement over a hydro tractor. It is WAY more quieter than a hydro, and puts WAY more power to the ground.
   / Confused: CVT vs. Hydro?? #16
I much prefer my CVT over my HST. It is quieter and more responsive, seems to have more power to the ground. The Boomer 8N CVT is my tractor, the TC40DA HST is my wife's.
   / Confused: CVT vs. Hydro?? #17
I love the CVT. It does not have the hydro whine, which means I just listen to the diesel rumble that I love in a tractor. In addition, all the power is transferred, so the 50 hp 8N is a legitimate 50 hp of useable power.
I think the 8N is currently the best buy on the market. CVT trans, 50 hp, and kicking good looks. How could you go wrong?
   / Confused: CVT vs. Hydro?? #18
I can see how a CVT would be more reliable than an automatic transmission (no rubbing clutch packs). I can even see how it would be more reliable than a geared system with a clutch. I can see how it would deliver more power to the ground than a pure HST. What I don't see is how they can say there would be less wear than an HST, or how they can make claims that it puts as much power to the ground as a purely geared unit.
If I am understanding the application correctly you would still need to clutch this or use a torque converter to decouple the engine from the drive system. You also have to have some sort of reversing gear. The torque converter would have losses similar to a very efficient HST. Just think automatic transmission. The reversing gears would still wear. I am just not seeing how this would have less wear than a really good shuttle shift type system that replaces the clutch with a torque converter. I would be concerned with wear in the meshing of the vari-pulley/sprockets and the drive chain. You have to have some sort of mechanical contact to transfer power. That means wear.
You'll have to excuse me if I remain skeptical. A lot of the info in here sounds more like marketing material than an engineering analysis. I am sure they are nice and work well. I just don't buy all the hype. I doubt most people can really tell if there is 48 vs 50 hp making it to the ground. Usually it's the feel and responsiveness of the controls that make the difference.
   / Confused: CVT vs. Hydro?? #19
It's not hard to tell how much more power is going to the ground. I started a job with the hydro unit, dealer delivered my CVT to the job, took the box blade off the hydro and put it on the CVT. It took about 1 hour to get the hang of the Farmall 40 and after that I was sold on the CVT. I used both units in the same day, doing the same thing under the same conditions. Trust me, the CVT puts more power down.
   / Confused: CVT vs. Hydro?? #20
The CVT in the 125 Hp and above that has been used for years is nothing like the system used in compacts. The larger ones use a planetary gear set and a partial hydo to vary speed.
The one NH is using is more like a snowmobile set up.
http://www.farmdepot.biz/CVT-Fact-VS-Myth.pdf
YouTube - ‪New Holland T7000 Easy Drive CVT Transmission‬‏
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
WATER TRAILER (A58214)
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
yellow ball Trailer (A56859)
yellow ball...
