Conoco Tractor Hydraulic Fluid
   / Conoco Tractor Hydraulic Fluid #21
post what you find.
soundguy
   / Conoco Tractor Hydraulic Fluid #23
sounds like a very 'greene' article to me.. perhaps enticing greene machine owners to buy branded oil...
soundguy
   / Conoco Tractor Hydraulic Fluid #24
soundguy
Yeah, gotta factor that in, but still. Enough concern expressed to be careful, I think. There are blenders and then there are blenders, I should think.
   / Conoco Tractor Hydraulic Fluid #25
If I bought an oil that ONLY met the 303 or 20a spec.. I might be concerned. but you see 20 other specs listed on most of the utf sold today.. some of them on the much newer end...
soundguy
   / Conoco Tractor Hydraulic Fluid #26
Update:
Got the report back from the lab. There was no contamination and everything was pretty much in order.Only areas above tolerances were high silicon and lead.
So spank me as I was falsely blaming the fluid manufacturer.
I do notice hydraulic pump singing when cold and surmise it prob the new filter may have some flow restriction.
I will in the future change fluid and filter more often.
Tom
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Topsoil Trommel (A57453)
Topsoil Trommel...
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
2013 Ford F-250 Crew Cab Pickup Truck (A59230)
2013 Ford F-250...
CATERPILLAR TL642C TELESCOPIC FORKLIFT (A60429)
CATERPILLAR TL642C...
