Conoco Tractor Hydraulic Fluid
   / Conoco Tractor Hydraulic Fluid #21
post what you find.
soundguy
   / Conoco Tractor Hydraulic Fluid #23
sounds like a very 'greene' article to me.. perhaps enticing greene machine owners to buy branded oil...
soundguy
   / Conoco Tractor Hydraulic Fluid #24
soundguy
Yeah, gotta factor that in, but still. Enough concern expressed to be careful, I think. There are blenders and then there are blenders, I should think.
   / Conoco Tractor Hydraulic Fluid #25
If I bought an oil that ONLY met the 303 or 20a spec.. I might be concerned. but you see 20 other specs listed on most of the utf sold today.. some of them on the much newer end...
soundguy
   / Conoco Tractor Hydraulic Fluid #26
Update:
Got the report back from the lab. There was no contamination and everything was pretty much in order.Only areas above tolerances were high silicon and lead.
So spank me as I was falsely blaming the fluid manufacturer.
I do notice hydraulic pump singing when cold and surmise it prob the new filter may have some flow restriction.
I will in the future change fluid and filter more often.
Tom
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2020 FREIGHTLINER M2 SINGLE AXLE BOX TRUCK (A54607)
2020 FREIGHTLINER...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
