Convert 3ph on TU155 to double-acting hyd?
   / Convert 3ph on TU155 to double-acting hyd? #11
>>(Is it possible to modify the 3ph to be able to hydraulically lower (ie under power, instead of gravity)?)
Would adding weights to the implement give almost the same result as downward hydraulic force?
   / Convert 3ph on TU155 to double-acting hyd? #12
   / Convert 3ph on TU155 to double-acting hyd? #13
Anything is possibly, but it isn't econpmically feasible. Adding weight to the implement is simpler
   / Convert 3ph on TU155 to double-acting hyd? #14
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56435)
2016 KBH...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
FORD 3PT. REVERSABLE SCOOP PAN (A52708)
FORD 3PT...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
1298 (A58374)
1298 (A58374)
