Convert 3ph on TU155 to double-acting hyd?
   / Convert 3ph on TU155 to double-acting hyd? #11
>>(Is it possible to modify the 3ph to be able to hydraulically lower (ie under power, instead of gravity)?)
Would adding weights to the implement give almost the same result as downward hydraulic force?
   / Convert 3ph on TU155 to double-acting hyd? #12
   / Convert 3ph on TU155 to double-acting hyd? #13
Anything is possibly, but it isn't econpmically feasible. Adding weight to the implement is simpler
   / Convert 3ph on TU155 to double-acting hyd? #14
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
GRAIN AUGER (A52708)
23018 (A55758)
23018 (A55758)
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2015 Nissan Rogue SUV (A56859)
2015 Nissan Rogue...
