Convert Miller 130 to gas, and classes?
   / Convert Miller 130 to gas, and classes? #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
I got a Miller 130 from a friend. He always used flux wire. How hard is it to convert to gas, and where to get the parts to do that?
I have never welded till now. Looked locally; have not found any classes except at JC an hour away. Where's a good place to look for training? My friend I got the welder from moved from area. (I'm east of Sacramento, Ca).
   / Convert Miller 130 to gas, and classes? #2
Can't help you with the welder. I would call Miller to see if it is even possible.
Far as instruction, nothing beats one on one instruction! Run an ad in your local Craig's list or newspaper. To see if some welder would be willing to give you some welding instruction.
   / Convert Miller 130 to gas, and classes? #3
I have a Miller 135, it's worked flawlessly since I bought it new 12 years ago. I never used it with flux-core, I have very little experience with flux-core (gas only). It was my understanding that the previous version (130) was gas compatible. Look at the rear panel, and if there is a brass gas fitting, then it's compatible. You will then need a gas regulator, tank of 75/25 AR-CO2 and hose, and some .023 solid wire. There are hose+regulator kits too. Look at the drive spools, be sure the groove is for .023 wire - you may have to flip them around to feed .023 wire. Possibly a welder that old will need a new "liner" or other wear parts if it's been used a lot or not stored properly.
MIG Argon hose Weldcote ARG14X10 Hose, - Argon - 10 ' W/ Inert Gas Fitting - - Amazon.com
Regulator Lotos Argon CO2 Flow Meter AR03 Welding Regulator Gauge Gas Welder Regulation for Lotos MIG140, MIG175, TIG200, TIG200DC Welders - - Amazon.com
wire INEFIL ER70S-6 .023-Inch on 10-Pound Spool Carbon Steel Mig Solid Welding Wire - Arc Welding Accessories - Amazon.com
You have to get the tank at your local welding supplier. It will be a couple hundred$$, but not much to fill it.
See "welding tips and tricks MIG" on Youtube. MIG welding is about the easiest welding to learn. Having an experienced MIG welder looking over your shoulder is the best bet. Beware of stick-welders who tell you your machine is no good, that simply means they don't MIG. Which is a shame because they up their game in a few minutes by borrowing your machine with a more positive point of view. You have a FINE machine (for up to 3/16" thickness material) that will weld all day for 10 years. Maybe not at a production shop but certainly for the hobby welder you will never need a new welder unless your projects start to get thicker than 1/4" or so. You can weld thicker with that machine as you gain experience and technique.
   / Convert Miller 130 to gas, and classes? #4
I had a 130 machine once. It would run with or without gas, so its possible that your machine is already setup to run gas and all you need is the regulator and bottle. My personal opinion with that size machine, I would just stay with the flux core. With mine, I was always running out of gas, and usually right in the middle of a welding project. They are good machines. I used mine to build a flatbed for a ton truck, but the low duty cycle made that much welding a pain in the arsh. Good machine to learn on, but as your projects get bigger, you might find yourself wanting a bigger machine.
   / Convert Miller 130 to gas, and classes? #5
By the time OP's projects get bigger than a 1Ton flatbed he will know a bit about shop eqpt. What works, what doesn't, what the internet likes to warn you about that will never happen. Mudd are you sure it wasn't the 15A breaker in the basement that popped? That I think,,,,,, is usually the case with 115v MIGs, the guy was a newbie and he wants to think he ran up against duty cycle like the big boys talk about (but it was just the 15A breaker). :laughing: Just kidding mudd, but this happens!
But seriously, if you set that Miller130 on the top setting you need to find a 20A 115v circuit to plug into. I believe a washing machine circuit is 20A. Garage circuits might be 20A.(?). Look at your breaker panel for 20A breakers and use that circuit. If using an ext cord it needs to be as thick as your pinky finger. I've used 15A cords on 120v MIGs at full power on 20A circuit and a 15A cord works because you don't hold the trigger for more than what?.... 10 seconds at a time? No newbie welds for 2 minutes without letting up on the trigger. Very few experienced welders use a 115v MIG like that. They don't HAVE 115v MIGs anyway so they don't 'know' these things other than speculation found on the internet. Then they bought a bigger welder thinking duty cycle is a concern and ain't lookin' back. You WILL pop a 15A circuitbreaker with the welder at full power settings. However, on a 15A circuit, plenty of welding can be done on the machine's 3/4ths power setting.
I "hear" Aluminum welding is where a "regular guy" needs to pay attn to duty-cycle. I've never used a Miller 130, only a 135 (the next newer model). I have never had any MIG shutdown on me since starting MIG welding in 1980 (which includes 8 years using a Miller 135 on 115v and before that a 115v Hobart for ~7 years.).
Now it's time to cue up Shield Arc to reminisce welding on 2" thick pilings with a MIG running 1/8" wire between hits from the pile driver at 60 below in Fairbanks back in the '70s.:eek::eek::eek:
Other than that, enjoy your Miller. It's good stuff; a far sight better than the $179 entry-level machines out there. On the 135 the only thing I've ever had to do on it is change the liner once (and the tips of course) and every part is available.
I have 20A circuits in the garage :D And 10G extension cords. And generator.
   / Convert Miller 130 to gas, and classes? #7
The local wrought iron company that does security bars uses flux core...
Hey Robert... I was up your way picking up a Kubota RTV900... also looked at some property.
How is the Real Estate Market?
The reason I asked is the folks I met have a very nice place but are putting it up for sale because their kids all moved out of California and have no desire to return...
I've been hearing more of this... their daughters living in Utah and Montana
Seems a shame to have a retirement all planned and nice homestead only to find out no one in the family has any interest.
   / Convert Miller 130 to gas, and classes? #8
sodo, I think I have mentioned this before, my garage doesnt have breakers, it is old wireing with fuse boxes. My fuses are 30amp each for 115v and combined for 60amp 220v. Not a very good setup and something I have planned to change when I get the chance. Hitting the duty cycle on a 115v mig isnt all that hard to do when welding sheets of 1/8 in sheet metal. The machine also tends to give you a little warning its about to stop welding too. First, everything will be welding just fine, then you will start to notice some spitting and sputtering, and then it will just stops welding. Machine doesnt shut off as the fans will keep running, but there is a internal thermal breaker inside that breaks and stops the welding until it cools off. Most welding jobs, at least for me, are just a matter of welding a couple of inches at a time, but doing sheet metal, its hard to resist the temptation to try to to run the full lenght of the sheet. For my normal welding, I seldom hit the duty cycle, but if I am fabricating a large item, the tack welding will never hit the duty cycle, its when everything is tacked up and I am trying to finish a solid weld, that hitting the duty cycle can become common. I have been know to hit the duty cycle with my 220v machine, so I dont think its at all uncommon for someone trying to make as much weldment as fast as they can, to encounter the duty cycle of a small machine, or every on bigger machines commonly found in a hobby shop environment.
   / Convert Miller 130 to gas, and classes? #9
Two 30 amp fuses for a 220v circuit would still be a 30 amp.
If the fuses are not blowing it would seem you are up against the duty cycle.
   / Convert Miller 130 to gas, and classes? #10
To hit duty cycle you need a project like a truck-bed, where you have the machine on full-power, and the project has welds 10 feet long. And you also need a tight schedule, forced to weld as fast as possible. The boss crackin' a whip. This does not sound like an entry-level project. You can count on your balls the number of welders on this forum who have ever had a project like that. Neither uses 115v machines for any project but goofing around, and one of them is exaggerating. :) Any welder building a truckbed, has long ago purchased a 220v machine.
Mudd the project you describe does not exist in the beginners world. He has YEARS to weld to his hearts content, a few inches at a time, getting all kinds of projects DONE with that Miller, at great satisfaction. I keep seeing this advice (to pay attention to duty-cycle) offered to members who buy 115v MIGs, and it's not pertinent to a quality unit like a Miller (or Lincoln, or Hobart, or Everlast, and several others). I think that's old advice, maybe 30 years behind the times.
OK so you have more than 20Amps, maybe the machine was a $90 MIG? If thats the class of machine you are referring to I can't comment (I have zero experience with those). There are certainly a lot of new welders who want to see if a welder will help their projects, and they dip a toe in the water, buying a $90 (or $190) machine. Then find it doesn't take them very far. Agreed there. But there is NO PROBLEM with the Miller/Hobart/Lincoln/Everlast units, they've been good for something like 20 years.
   / Convert Miller 130 to gas, and classes? #11
Its a 60amp pull type fuse split to two 30amp screw in fuses, I have 60amps for my 220v
   / Convert Miller 130 to gas, and classes? #12
I am hesitant to even reply, seems you want to squabble over something thats not worth argueing about. As to a beginning welder, just what kind of inside knowledge do you have, or what kind of hint was given in this thread, that suggests the OP might not want to take on a bigger project once they start learning how to weld. Those little welders have their place, but the advice I gave I feel is accurate and not based on any assumptions, but on my personal experiences with welding machines. I have owned several different size welders over the years, and I have always owned one of the name brand machines, Never bought one for $90 either. I am not a professional welder, nor do I make my living in the welding industry so I have never ran a welder with a continuous duty cycle, but I have ran plenty of welders that have hit the duty cycle while running a bead.
   / Convert Miller 130 to gas, and classes? #13
Every time a new welder pops in on any forum; "duty-cycle" is dangled in front of him. If the machind is 10%,,,,, well then maybe. I've never used a 10% machine, maybe thats why I don't believe it.
   / Convert Miller 130 to gas, and classes? #14
muddstopper do not argue with the resident expert!
Another thing, he is the only member here with a crystal ball! He looks in his crystal ball and can see what is best for all members! :rolleyes:
   / Convert Miller 130 to gas, and classes? #15
Haha, I've seen a lot of advice from some welding 'experts' here. I can't see whats best for all members but can call out what's useless to a newbie. And predict what advice will be offered to every newbie. Duty-cycle comes up a lot. On the forum it's just an internet thing like chainsaw size, tractor size, truck GVW,,,,and stuff like that. You won't see in real life except maybe with a budget machine (less than $200? Less than $100?)
472385d1466607455-convert-miller-130-gas-classes-predict_useless_advice-jpg
Remember this is a tractor sub-forum. It's a great place to put actual tractor welding because often someone has fixed what you need to fix. Due to experience can provide a point of view that is useful, looking at the whole project not just the welding. Newbies should read "weldingweb.net" too. There are more members over there who actually remember what a newbie needs to know. If someone posts bad advice or just wants to brag about a big welder there are MORE other members to balance it out with good advice.
   / Convert Miller 130 to gas, and classes? #16
You sir are an idiot in the most polite manner that I say it.
I would probably still be classed as a newbie welder (only three years and about 250 lbs of rod) and I have never yet seen anything that you have posted that had value to a newbie. I am certain that there has been something, but the blather that you put out 99% of the time masks anything of value that you might have said at some point in the past.
I read the welding posts to learn and have learned much from many folks.
I have learned from you as well. I have learned that you are a blowhard: a person who talks too much and who has strong opinions that other people dislike
Blowhard | Definition of Blowhard by Merriam-Webster
Post away but stop the nonsense. You exhibit many traits and qualities none of which are desirable in a civil discussion.
Rant off
   / Convert Miller 130 to gas, and classes? #17
That sounds pretty civil Silvic! Good luck with what you've learned. Ability to read a forum and pick out what's useful is a worthwhile forums skill. I'm thankful for your posts to help forum members.
   / Convert Miller 130 to gas, and classes? #18
I believe a miller 130 has a 20% duty cycle at 90 amps. Thats 2 minutes of welding out of every 10 minutes. 90 amps is good for about 1/8in thick metal using soild wire and gas mix. Flux core will get you up to about 3/16. For body work and such, the little migs are good machines, but I dont feel its reasonable to expect a 130amp mig to weld more than two or 3 minutes before hitting the thermal shutdown and stop welding. Since this is a tractor forum, one could think any welding would be tractor related, just how many implements have you seen that are made using only 1/8in thick material. welding thicker material is going to take more amps to do so correctly and higher amps is going to lower the duty cycle of the machine. I built a quick attach for my brothers fel, thats tractor related, and not something I would even consider using a 130amp mig to do. Just because a person is not welding on the clock for a paycheck, doesnt mean they should be limited to making a 2in long weld and then waiting 10 minutes before making another similar weld. My number one reason for upsizing my welders to bigger machines has always been because i get tired of the machine shutting down before I can complete my project. My first mig was a 125 hobart handler, the next a 135 lincoln and my current mig a 175 miller. I use the miller to tack up large projects and then pull out the 250/250 stick to zipp everything together. My next mig will probably be a 250amp machine, as soon as I find a good used one somewhere at a reasonable price. I would go even bigger, but I dont have access to 3phase power. to sme folks, duty cycle might not matter, but I am willing to let that person come to my shop, with their little welder, and experience what it is like to try and weldup some of my projects with thier limited duty cycles. They can feel free to experience all the fustrations that go along with the machine shutting down, and having to wait to finish the project because the welder isnt up to the task. If your not hitting the duty cycle of your little machines at home, you not serious, your just playing.
   / Convert Miller 130 to gas, and classes? #19
Ambient temp can make a difference regarding duty cycle.
Also, preheating the work helps.
There are different machines for different purposes...
   / Convert Miller 130 to gas, and classes? #20
I suppose by your assessment, 99% are just playing. I bet 90% admit it proudly. But basically a 20% duty cycle is a good strong machine that will (probably) never shut down. And if it does, you can put a little feather in your cap and exaggerate on the forum that it happens all the time (just like the big kids). ;) I'm not so lucky, haven't had a shutdown in 30 years.
Mudd sounds like more happens at your shop than mine. We need to see more of your projects.
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
402 (A52706)
402 (A52706)
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
John Deere 4600 (A53317)
John Deere 4600...
