Converting a woodsplitter into a firewood processor
   / Converting a woodsplitter into a firewood processor #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
Ive begun the process of converting my homebuilt Timberwolf clone splitter into a processor. Sorry for being slack with the pics, I keep forgetting the camera
The build thread for my splitter is here: http://www.tractorbynet.com/forums/build-yourself/219145-woodsplitter-build-timberwolf-clone-7.html
Before:
Im using the Wallenstein WP processor as the basis for my conversion. Instead of the complications of a hydraulic saw, Im using a gas powered chainsaw. There will be a home made hydraulic winch as well
Log cradle. Made from 1.25" and 2" square tubing.
"Custom" bar nuts. M8x1.25 coupler nuts are not available local. So I welded a M8 nut onto a 7/16" standard coupler nut
Mockup of hinge
Closeup of saw mount. Saw will be easily removable, just like the Wallenstein
Ill try to grab some better shots. These were all that was on my phone
   / Converting a woodsplitter into a firewood processor #3
I need the pics!!!!
Mockup of hinge
Infeed ramp and hinges
Figuring out the layout for the winch
If there is still an issue, let me know
   / Converting a woodsplitter into a firewood processor #6
How is your saw mounted on to the machine
   / Converting a woodsplitter into a firewood processor #7
I have been to alot of auctions seeing bits and pieces of firewood processors being sold. One guy worked for the state of Ohio and he even had the harvestor chain, bar, and pump aquired for his build. Several three valve bodies were also sold along with a three ft. x five inch cylinder.The stuff was not in one group but was sold thru out the day. I figured it out to late. Your build looks well thought out and nicely executed.
Thanks.
It would be nice if there was those types of auctions here!!
Made a hole cutter for my torch. To cut out the end plates for the winch spool
Welding the spool
Finished winch
(6) Front Tractor Weights (A46502)
(6) Front Tractor...
2010 Ford F-150 Pickup Truck (A46684)
2010 Ford F-150...
4'x8' Quick Attach Safety Basket (A47307)
4'x8' Quick Attach...
2017 CAT 239D Track Skid Steer (A46502)
2017 CAT 239D...
2105 (A46502)
2105 (A46502)
Custom Drawbar (A46502)
Custom Drawbar...
