I third or fouth the out door wood burner. Mainly because I heat with one.
I went with the duel fuel option. I can set it to wood only, wood over oil (if the temp drops, the oil kicks in ie go away for the weekend), a clean start option (oil runs till the wood takes over) or oil only (why??)
It runs radiant heat in the basement and garage, and a heat exchanger heats the top floor with forced hot air. It also heats my 80 gal hot water tank.
I have a Central Boiler
www.centralboiler.com actually its a hydrofire, by Central boiler
http://www.hydrofire.com/products.html#HFSS36 The draft is temp controlled by a thermometer in the tank connected to a selonoid that opens the draft on demand. The temp is controlled by 3 thermostats in the house. 1 for the basement, 1 for the garage, and one for the upstairs. The basement and garage thermostats control valves to let heat into the radient pipeing, the upstairs controls the blower.
I went with forced air upstairs simply that if I decide to put in AC, the ducting is there already. Plus, I like some air movement in the winter. Not that I dont get it with the kids running in and out /forums/images/graemlins/grin.gif
There is NO open flame in my house, the insurance guys like that.
You can burn anything in them, pine, oak, sassafrass, it doesnt care. If you have a chimney fire, you just look out the window and then finish your coffee.
When it is REAL cold. < 0 F, I have to fill it twice a day. When I leave for work, and before I go to bed. If its extremely bitter, the wife will toss a few in at lunchtime. The model I have is about the smallest Hydofire they make. I could have gotten a bit larger, probably should have, just to extend the burn time a little, but its fine. I heat around 3500 + sq feet, and the basement isnt finished so my burn time will go up once I get the walls up and retain more heat. OS walls are 6 in insulated, basement is precast concrete with 1 in foam board (R5)and 6 in R19 + the R of the concrete.
edit:
A outdoor woodburner can be tied to your existing heat system. I would not go with one unless you have access to wood, doesnt have to be good wood, but you need wood.
Cost total, Ummmmmmmmm, I think the unit was right around 6Kish. You can get cheaper makes. I looked, and I wouldnt. You can get cheaper units from Central Boiler, If it was a backup, yes I would have skipped the stainless steel firebox.
