Cooler tip
   / Cooler tip #11
I'm not saying it doesn't work, but I'm kind of puzzled by the physics. I would have thought that a contained air pocket would be a better insulator than any type of filling.
   / Cooler tip #12
Alch:
Insulation is to SLOW DOWN heat transfer. If it is just AIR then there is little to slow the heat transfer. If it is FOAM then it is billions of little air bubbles separated by foam that keeps air and heat from migrating as easy. Fiberglass does the same thing in a hollow cavity in your wall it basically slows the heat transfer only.
Mark
   / Cooler tip
Cmon now... Why would you insulate your walls, attic, floors etc if a contained air pocket would be better :D
   / Cooler tip #14
Hmm.. air is better insulating than foam/air...
   / Cooler tip #15
You insulate the wals to keep the air from moving. moving air does not insulate (why you have vents in your attic). Fiberglass only slows the air down. Foam traps it. Drilling holes in your sealed, air insulated top to add foam reduced the insulating value.
   / Cooler tip #17
Walls and ceilings are not a contained air pocket. I understand how insulation works. The thicker the insulation, the better it works because more air is trapped in the batt. But the use of batts rather than air pillows is probably just a matter or practicality.
   / Cooler tip #18
Alch:
Mark
I'm not sure that would actually stand up to a scientific test.
   / Cooler tip #19
We also do this or old thermos' s that stop holding heat. When the vacuum is gone they are inefficient a small hole in the bottom and some foam although it makes them heavier is keeps stuff hot longer.
   / Cooler tip #20
Makes good sense, :thumbsup: Thanks!
I'm sure the adhesion when once dried helps to reinforce the lids, Know anyone who sits on their coolers,;)
I have a couple of mine that I sit on. They aren't new coolers. Like everything else, i doubt the new coolers would be as tough or forgiving.
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A55787)
2007 Godwin Pumps...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2019 KENWORTH T680...
UNUSED LANDHONOR 3.5X2X2M GREENHOUSE (A54757)
UNUSED LANDHONOR...
Online Buyers Premium (A47477)
Online Buyers...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
