Cordless grease gun?
   / Cordless grease gun? #31
<font color="blue"> Do the guns with the flexible hose require the use of one hand to hold the hose tight to the fitting while the other hand controls the grease trigger? </font>
The Lincoln cordless grease gun I have has a flexible hose. Usually, the hose 'snaps' on to the fitting, so there's no need to use 2 hands.
   / Cordless grease gun? #32
Bob, I've just encountered too many places that I couldn't get a rigid stem onto a grease fitting, so when I got a grease gun with a rigid stem, I promptly replaced it with a flexible one. If I knew I was only going to be using it where the rigid stem would fit, that's what I'd use. With the flexible stem, it usually requires two hands to get it on the fitting, but then it should stay while you pump the grease.
   / Cordless grease gun? #33
I had a g/gun with a rigid stem.. it worked GREAT on the easy to reach fittings. Then there were those ( on my 1920 ) that could only be reached via flexible hose.. and yes.. you have to hold them to grease them. ... which creates a problem. Usually I have to prop thge gun against my leg.. use one hand to pump the handle, and the other to hold the end on the fitting.
Seems like an electric one would make that easier.
Soundguy
   / Cordless grease gun? #34
Soundguy,
I have a standard cartridge grease gun with pistol grip lever and flex hose. I recommend this setup for anyone using a manual gun. I have been the lever type route too /forums/images/graemlins/frown.gif
   / Cordless grease gun? #35
I hadn't thought about a hand pump type... nice idea.
Soundguy
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
16FT Flatbed Truck Body (A52377)
16FT Flatbed Truck...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
