Corrosion in Electric Panel ... What to Do?
   / Corrosion in Electric Panel ... What to Do? #31
He also said that when I run to another subpanel to the barn, to bring 4 wires to the barn sub, float the neutral and that I won't need to keep the ground rod there that I recently put in.
The ground rod at the barn will provide greater immunity from damage due to lightning.
Wrooster
OK, thanks wrooster. I'll leave the ground rod in place at the barn, in addition to running the ground from the house subpanel to the barn subpanel. And thanks for the clear and helpful diagram. I plan on also bonding the metal barn siding to the ground.
This is the case with a feeder to a subpanel in a detached structure, such as a detached garage.
When the sub panel is in the same structure and is wired with a 4 wire feeder (L1/L2/N/Gnd), the sub panel does not require a supplementary ground rod.
Wrooster
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2007 GMC W4500 Landscape Dump Truck (A55788)
2007 GMC W4500...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A54607)
2019 INTERNATIONAL...
Scag Mower (A50324)
Scag Mower (A50324)
