Rolando
Platinum Member
- Joined
- Aug 20, 2004
- Messages
- 586
- Location
- Northcentral Florida
- Tractor
- Bobcat Toolcat High Flow Turbo C-series
LBrown59 said:...Here is a close up look at the $99 pump I got on sale for $69 at northern tool.
http://i283.photobucket.com/albums/kk286/lb59/100_2296.jpg...
I was looking at your filter setup. I want to set up my own fueling station and I'm trying to learn as much as I can about how people make their decisions.
Is there any other difference, between the type of filter you're using and the kind that has a clear case with the fluid and filter canister visible, that you can see the amount of sediment residual and being able to remove it with the drain valve below the filter?
Also, it doesn't look like you have a particle filter, just water block. Any particular reason why one and not the other, or instead of the other?
