Cost of cutting edge
   / Cost of cutting edge #11
Tractorganic said:
Slippy, you should consider a bolt on tooth bar to go over your cutting edge. You mention removing old blacktop as a first project and a toothbar will bite into that stuff easily helping to break it up, get underneath it, and slice it into the bucket saving a great deal of wear on your FEL.
Do toothbars cover the entire cutting edge? Or do they just cover the areas that have the teeth?
Bob
   / Cost of cutting edge #12
Sorry, I was wrong. I got the toothbar in Aug. '04 along with a Farmi logging winch. It's a Woods TB40735 and cost me $550. That NH dealer doesn't discount very much though, and it may come cheaper elsewhere. This may be cost prohibitive for Slippy but I have found it to have paid for itself quickly by time saved digging and greater capacity hauling.
   / Cost of cutting edge #13
Part #s for NH HD toothbars for use over Factory Bolt on cutting edge.
NEW HOLLAND HEAVY DUTY TOOTHBARS
(FOR BUCKETS WITH BOLT ON CUTTING EDGE INSTALLED)
DESCRIPTION PART#
60" 7 TEETH 86599706DS
66" 7 TEETH 86599707DS
72" 7 TEETH 86599708DS
78" 8 TEETH 86599709DS
84" 8 TEETH 86599710DS
Found them on Messicks website under Parts.
   / Cost of cutting edge #14
Yes Doc Bob it's 72" end to end, slips over the cutting bar and inside the bucket where a bracket on each end 'through bolts' to the bucket. These bolts are beefy and take time to remove if I want to drop the toothbar and run with the cutting edge. I worry about bunging the bolt threads with some of my rock hauling; but I'd rather have them heading into the bucket than out (they protrude about 3") where I'm likely to forget and gouge myself. I have removed it to prepare for snow, but even then I've found busting up thick ice is so much faster with it on that I keep it on all winter. I have a dirt driveway which the Town plow loves to backfill with some nasty hard pack. One run with the bucket cleans up that whether it's slush or solid. This may be where I get out the digital camera and learn to post a pic. Too dark now, I'll try tomorrow.
Local dealer told me he has 4 tooth bars in stock for the 72" bucket. Price was over $400.00
   / Cost of cutting edge #16
If pretty sure NH uses FFC tooth-bars, at least that's where my 72" bar came from. FFC
   / Cost of cutting edge #17
Finally I may be able to upload a picture, here's my toothbar as discussed above.
PALLET OF COULTERS & WEAR SHINES (A52708)
PALLET OF COULTERS...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
Mini Excavator Hydraulic Thumb (A55272)
Mini Excavator...
2016 Ford F-150 Pickup Truck 4x4 (A56858)
2016 Ford F-150...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2019 INTERNATIONAL...
10' Container W/Side Door and Window (A57149)
10' Container...
