Counterweight for TC33D
   / Counterweight for TC33D
Looking at the top link mounting assy on the TC33, I don't feel comfortable putting all the weight (stress)on the top link. Aren't the lift arms meant to support the weight ? (It's within the 3PH lift specs for the tractor as listed in the manual)
   / Counterweight for TC33D #22
</font><font color="blue" class="small">( Aren't the lift arms meant to support the weight ? (It's within the 3PH lift specs for the tractor as listed in the manual) )</font>
Tom, I think you are correct. The Class III tractors have a relief valve built right into the lift cylinder to allow pressure relief due to high shock loads. That pressure is about 3,600 lb on my tractor, I'm not sure what it would be on the Class IIs, but it is at least half-again the lift capacity of the 3PH. With your ballast box you should never experience any stressing of the hydraulics, even if you hit a bump and transmit a shock load to the arms. /forums/images/graemlins/cool.gif
Jim......I know that before I installed the counterweight any quick movement of the loader caused the tractor to shake or jounce around. With the weight on, none of that occurs anymore. I also made pads on the bottom of the weight assy to set the weight on so I could lower it to the ground when not using the tractor to take the stress off the 3PH hydraulics & tires etc. The quick on & off features of the loader & weight will also make the transition back to lawnmowing with the MMM a short job in the spring.
UNUSED IRGC40 HIGH END MINI GOLF CART (A58376)
UNUSED IRGC40 HIGH...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
Giyi 72" Grapple (A57149)
Giyi 72" Grapple...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
